Home Hub 5 OpenRG Reboot?
jslane
Does anyone know what would cause my Home Hub 5 to receive a reboot command? I was busy working then all of a sudden the router rebooted and I lost connection! It's happened a few times, looking at the logs, but I only noticed it today with me being remotely connected to a server. I know it's not a plusnet router, but I'm sure some of you will know what it is! Smiley
13:59:16, 14 May. (1213276.220000) The system is going DOWN for reboot.
13:59:16, 14 May. (1213276.220000) OpenRG is going for reboot by IPC command
13:59:11, 14 May. (1213271.220000) OpenRG will go down for reboot in 5 seconds
g1000
Re: Home Hub 5 OpenRG Reboot?
It is the HomeHub itself rebooting, it is an internal command. Is it happening every 14 days?
jslane
Yep! It looks like it reboots around every 14 days. I guess I better start looking for another router and put this one on eBay!
