Home Hub 5 Help
- Home Hub 5 Help
Home Hub 5 Help
29-07-2014 5:43 PM
I hope I'm allowed to start a new thread about a problem I have been left with since my system went down almost 2 weeks ago.
I have used a BT Home Hub 5 for some months as wi fi is far superior to the Plusnet supplied router but it could not be used once I re-connected back to the internet.
The power light glows orange and the b below is also orange indicating broadband connection but no active account. I entered my details again (username@plusdsl.net and password) but the cursor simply goes back to the start of the username box.
Anybody any ideas how to fix?
I don't want to buy another as it seems to be working except that my account is not being recognised so is probably not a hardware fault. My initial fix did not last as all of details were not taken across when my connection was lifted and shifted (moved to another port in the green box) and I wonder if it is related to that
Message 1 of 7
(1,116 Views)
6 REPLIES 6
Re: Home Hub 5 Help
29-07-2014 5:47 PM
As you have started a new thread after appearing to suggest that the original thread be moved here I have locked it to prevent confusion
This was the original http://community.plus.net/forum/index.php/topic,129743.0.html
Message 2 of 7
(583 Views)
Re: Home Hub 5 Help
29-07-2014 8:49 PM
@kelvin - Is your connection ADSL or fibre? Do you have the router connected via the grey Broadband DSL port, or the red Broadband WAN port?
If you are on fibre and have the cable connected directly from the grey DSL port to the fibre socket, what happens if you connect the fibre modem, and connect the Hub 5 via the red WAN port to port LAN 1 on the fibre modem?
Message 3 of 7
(583 Views)
Re: Home Hub 5 Help
29-07-2014 9:12 PM
I did have a similar problem actually, and a factory reset solved it for me.
Message 4 of 7
(583 Views)
Re: Home Hub 5 Help
29-07-2014 9:52 PM
@Oldjim - Sorry for the confusion. Thanks for locking the previous thread
@Jaggies - I am on fibre and have the cable connected to the DSL port. I was hoping to stop using the modem so that I have just the one box in use. I will try connecting to the modem just to see if it works.
@Devonian - The factory reset did remove connection details but it would not accept my details and move onto the next step. I will try again if it worked for you.
I may be wrong but my experience with the first fix where my new port was not set up correctly suggests it may be related to that.
Message 5 of 7
(583 Views)
Re: Home Hub 5 Help
29-07-2014 9:59 PM
This maybe a silly suggestion, but are you sure your broadband is working?
When mine was down, I was unable to enter my login details.
Message 6 of 7
(583 Views)
Re: Home Hub 5 Help
29-07-2014 10:19 PM
@Devonian - The broadband light on my (Plusnet) modem is green, I am connecting to the internet and speedtest.net is showing download speed at 60 Mbps. I am even getting almost 30Mbps wi-fi tonight.
I will try again tomorrow but connection via wi-fi with the Plusnet modem has not left me fuming as they did last night
Message 7 of 7
(583 Views)
