Higher than normal SNR margin after more line faults
- Re: Higher than normal SNR margin after more line ...
27-01-2013 10:44 AM
Hi again.
Just when everything had settled down, a couple of weeks ago BT replace a long segment of faulty cable. When my router eventually reconnected, the SNR margin appears to be set to 12db again and consequently the line speed is low (1500-1660 kbps). I left the router up for over two weeks without a reboot/reconnect and it was stable with very few FEC errors so I rebooted it a couple of times this morning hoping that the exchange would have reset the SNR margin to something more sensible but the line still came up slow with a 12db SNR margin.
Could the SNR margin be set to a lower level now please so that my download speed is something sensible? IP profile only giving me a download of 900ish kbps atm
Regards
Regards
Message 1 of 4
(754 Views)
3 REPLIES 3
Re: Higher than normal SNR margin after more line faults
28-01-2013 10:14 AM
Any chance someone could look at this please?
Message 2 of 4
(426 Views)
28-01-2013 2:17 PM
Hi FarmerGiles,
Sorry for the delayed response.
I've placed a SNR reset on your line, this should complete in the next 4 hours.
Let me know how you get on.
Message 3 of 4
(426 Views)
28-01-2013 3:11 PM
Hi Chris
Now synced at 2240 with 6dB SNR Margin Current SNR 7dB.
Will monitor for stability etc
Regards and thanks.
Regards and thanks.
Message 4 of 4
(426 Views)
