Higher Upload Speeds
- Re: Higher Upload Speeds
12-02-2014 3:51 AM
I've been looking at streaming on Twitch lately.
In Call of Duty Black Ops 2 there is an In-Game Livestream option that requires an Upload Bandwidth of 1.5mbps to even start streaming.
On my current package I am only getting half that, roughly 0.700
Is there anything I can do to raise my Upload?
Message 1 of 7
(1,030 Views)
6 REPLIES 6
12-02-2014 9:48 AM
The only real option you have (assuming you're on 21CN - Up to 16Mb) is to add Annex M onto your line.
Annex M is only really effective for the shorter lines if I'm honest. I wouldn't generally add Annex M to lines that have an upload speed lower than 1Mb.
Annex M is charged at £12 per month (inc. VAT).
Message 2 of 7
(615 Views)
12-02-2014 5:51 PM
What exactly is Annex M?
And what would it do if I connected it to my line?
Message 3 of 7
(615 Views)
12-02-2014 6:30 PM
What are your present sync speeds
Message 4 of 7
(615 Views)
12-02-2014 6:39 PM
Quote from: GameGenieBob What exactly is Annex M?
'Annex M' uses a larger part of the available DSL 'Bandwidth' for upstream (consequently a similar amount less for downstream). 'Normal ADSL2+ is 'Annex A'.
This explains the technical bit: http://en.wikipedia.org/wiki/ITU_G.992.5_Annex_M
Call me 'w23'
Message 5 of 7
(615 Views)
12-02-2014 6:53 PM
Quote from: Oldjim What are your present sync speeds
Assuming this is what I need to do to find out my Sync speeds
http://www.speedtest.btwholesale.com/
I will have to wait until the initial 10 days are over, so it says.
I have run various different speed checkers and they all seem to give different results.
Message 6 of 7
(615 Views)
12-02-2014 7:45 PM
No it isn't
You get them from your router http://community.plus.net/forum/index.php/topic,96155.0.html explains
Message 7 of 7
(615 Views)
