turn on suggestions
Higher UpStream/DownStream speeds - hot weather?
- Higher UpStream/DownStream speeds - hot weather?
05-09-2013 2:11 PM
I'm not complaining!
My connection speeds have been steadily increasing it appears:
DownStream Connection Speed 18998 kbps
UpStream Connection Speed 1171 kbps
Is this because of the hot weather? I'm on an EO line ...
Does a Download speed (SpeedTest) of 15.5Mb/s sound about right?
Any thoughts or comments?
Kind Regards and Many Thanks
Hugh
Hugh
Re: Higher UpStream/DownStream speeds - hot weather?
05-09-2013 2:17 PM
It's not impossible that it could be due to the hot weather.
I'm imagining a scenario where there's an issue with a poor cabling joint on the phone network and the cable could expand and "improve" the connection in higher than usual temperatures.
I doubt we'd ever be able to know for certain but that's my theory.
Adam Walker Plusnet Help Team |
05-09-2013 2:54 PM
Quote from: h_milsom Does a Download speed (SpeedTest) of 15.5Mb/s sound about right?
Yes, speed test results of 80-83% of sync speed are typical. Your BT IP Profile and Member Centre Current line speed should be 16.7Mbps. The IP Profile is the idealised maximum without any allowance for connection management.
David
05-09-2013 3:31 PM
Many thanks to Adam and to spraxyt!
Hugh
Hugh
