High pings
- High pings
Re: High pings
11-10-2009 3:20 AM
Re: High pings
11-10-2009 11:45 AM
Your problem is more likely to be exchange contention, or perhaps a transit problem with Telia
B.
Re: High pings
11-10-2009 10:24 PM
I am also having the same problem that this guy, and several other people too that I can see on this forum.
The thing that catches my eye the most, is that on each of our tracerts, the hop to the same part on all of ours has a high ping.
202 ms 184 ms 218 ms vl703.thn-gw2.plus.net [84.92.4.242]
Re: High pings
15-10-2009 6:22 PM
line stats show
DSL Connection
Link Information
Uptime: 1 day, 23:17:52
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 14.0 / 24.0
SN Margin (Up/Down) [dB]: 23.0 / 5.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 2 / 84,119
CRC Errors (Up/Down): 2 / 9
HEC Errors (Up/Down): 2 / 9
and trace route
Tracing route to server.directclanhosting.com [81.19.217.152]
over a maximum of 30 hops:
1 33 ms 99 ms 100 ms dsldevice.lan [192.168.1.254]
2 56 ms 61 ms 50 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 52 ms 53 ms 55 ms vl303.thn-gw2.plus.net [84.92.3.178]
4 57 ms 101 ms 54 ms vl23.pte-gw2.plus.net [212.159.4.28]
5 60 ms 66 ms 57 ms ae0-1234.rt2.the.uk.goscomb.net [195.66.224.226
6 52 ms 59 ms 54 ms tele-north.killercreation.co.uk [77.75.109.198]
7 55 ms 66 ms 80 ms 217.146.94.6 [217.146.94.6]
8 60 ms 56 ms 53 ms server.directclanhosting.com [81.19.217.152]
Trace complete.
Re: High pings
16-10-2009 9:58 AM
This tracert at 2 this morning (yep i know its a daft time)
* moemoff
* View Profile EmailPersonal Message (Online)
* Quote
* Modify
« Reply #73 on Today at 02:29 »
I play WOW ..this is what i am getting at 2 in the morning!
Tracing route to yyy.yyy.yyy.yy [67.215.65.132]
1 <1 ms <1 ms <1 ms my.router [xxx.xxx.x.xxx]
2 12 ms 12 ms 12 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 26 ms 12 ms 11 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 12 ms 11 ms 11 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 12 ms 12 ms 12 ms vl266.mpd01.lon01.atlas.cogentco.com [149.6.147.213]
6 12 ms * 12 ms te1-8.ccr01.lon01.atlas.cogentco.com [130.117.3.226]
7 86 ms 86 ms 86 ms te4-4.ccr01.jfk02.atlas.cogentco.com [130.117.0.185]
8 118 ms 117 ms 118 ms te3-3.ccr01.ord01.atlas.cogentco.com [154.54.29.145]
9 135 ms 135 ms 135 ms te3-4.mpd01.mci01.atlas.cogentco.com [154.54.7.185]
10 147 ms 147 ms 159 ms te4-4.mpd01.den01.atlas.cogentco.com [154.54.24.81]
11 164 ms 164 ms 164 ms te4-2.ccr01.slc01.atlas.cogentco.com [154.54.0.42]
12 164 ms 164 ms 164 ms te4-2.ccr01.smf01.atlas.cogentco.com [154.54.1.101]
13 179 ms 179 ms 179 ms te3-1.ccr01.sea01.atlas.cogentco.com [154.54.29.242]
14 183 ms 179 ms 179 ms te4-4.ccr01.sea02.atlas.cogentco.com [154.54.3.146]
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Makes playing a pain ...as it screen judders when it catches up. Also folks complain that your teleporting
My question ... why so many jumps in the atlas.cogentco.com network and do Plusnet make representations about this? Why do they route to atlas.cogentco.com if there is a known problem?
Re: High pings
16-10-2009 2:27 PM
Unfortunately, the latency on transatlantic hops is completely out of Plusnet's control - it's their Transit provider Cogent.
The traffic is taking the following route:
London
JFK
Denver
Seattle
You'll be totally at the mercy of the transatlantic capacity though.
B.
Re: High pings
16-10-2009 2:32 PM
Re: High pings
16-10-2009 4:46 PM
Re: High pings
16-10-2009 5:03 PM
Re: High pings
16-10-2009 5:18 PM
thats the transatlantic hop right there
Quote 6 12 ms * 12 ms te1-8.ccr01.lon01.atlas.cogentco.com [130.117.3.226]
and from doing a lookup it appears the final dest of that traceroute is
Hostname: hit-nxdomain.opendns.com
ISP: OpenDNS, LLC
Organization: OpenDNS, LLC
Country: United States
State/Region: CA
City: San Francisco
Re: High pings
18-10-2009 8:38 PM
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\ROY>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
1 77 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 57 ms 53 ms 44 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 59 ms 51 ms 82 ms gi2-2-303.ptn-gw01.plus.net [84.92.3.9]
4 48 ms 81 ms 46 ms te2-2.thn-gw1.plus.net [212.159.1.54]
5 263 ms 219 ms 226 ms te2-3.thn-gw2.plus.net [212.159.1.58]
6 132 ms 188 ms 133 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 50 ms 45 ms 64 ms 212.58.238.149
8 46 ms 48 ms 49 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
Re: High pings
18-10-2009 8:49 PM
Re: High pings
28-10-2009 7:12 PM
C:\Users\ROY>ping bbc.co.uk
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=45ms TTL=121
Reply from 212.58.224.138: bytes=32 time=41ms TTL=121
Reply from 212.58.224.138: bytes=32 time=144ms TTL=121
Reply from 212.58.224.138: bytes=32 time=43ms TTL=121
Ping statistics for 212.58.224.138:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 41ms, Maximum = 144ms, Average = 68ms
Re: High pings
28-10-2009 9:27 PM
Please do this for me, Im interested to know your results:
Find the IP address of your router (You know the IP to see your router settings etc)
Then ping it 100 times, type this below (with your IP though obviously)
ping 192.168.1.254 -n 100
Post results
Re: High pings
28-10-2009 9:40 PM
Although my internet is generally fine now.. I was just doing a tracert for the sake of it after reading this thread. I did a few
Whats this high latency, Is it Plusnets gateway?
1 76 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 43 ms 56 ms 50 ms lo0-plusnet.pcl-ag02.plus.net [195.166.128.39]
3 68 ms 51 ms 49 ms gi1-2-904.pcl-gw02.plus.net [84.92.0.141]
4 89 ms 208 ms 201 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 33 ms 48 ms 65 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 35 ms 60 ms 72 ms 212.58.238.149
7 39 ms 49 ms 53 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Moment later, there is no latency increase
1 63 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 69 ms 59 ms 36 ms lo0-plusnet.pcl-ag02.plus.net [195.166.128.39]
3 35 ms 82 ms 47 ms gi1-2-904.pcl-gw02.plus.net [84.92.0.141]
4 35 ms 33 ms 36 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 32 ms 32 ms 33 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 35 ms 34 ms 32 ms 212.58.238.149
7 37 ms 68 ms 70 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Oh but a moment later again! There is another latency increase, is that the Plusnet gateway? & the last one plusnets website?
1 79 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 32 ms 32 ms 32 ms lo0-plusnet.pcl-ag02.plus.net [195.166.128.39]
3 33 ms 41 ms 32 ms gi1-2-904.pcl-gw02.plus.net [84.92.0.141]
4 32 ms 32 ms 31 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 74 ms 203 ms 204 ms te2-3.thn-gw1.plus.net [212.159.1.57]
6 33 ms 32 ms 32 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
7 42 ms 42 ms 42 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
8 43 ms 43 ms 42 ms 212.159.0.26
9 48 ms 42 ms 44 ms if25.pih-lb04.plus.net [212.159.0.18]
10 148 ms 79 ms 41 ms portal.plus.net [212.159.8.2]
Is Plusnet having problems in the evenings atm or what? (I think so) // If so, any ETA on when it will be fixed?
