High pings
ryoken
High pings
Hi
After my d link router went belly up  i was sent a thompson tg585 v7.
Set up was easy , but i have two problems, my ping times in the servers i use have jumped from around 50 ms to anything up to 1500 ms.
Secondly (probably me being a doof) where do i find my router stats? i cant seem to find any details from the thompson.
I have run speed tests which seem fine
Date                      Download Speed                      Upload Speed
Today10:23          5983 kbps (748kB/s)                371 kbps (46.4kB/s)
Also ran a trace route (which means nothing to me 🐵
C:\Users\ROY>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
  1    17 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    48 ms    43 ms    44 ms  lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
  3    43 ms    42 ms    42 ms  vl604.thn-gw1.plus.net [84.92.4.169]
  4    42 ms    43 ms    42 ms  te2-3.thn-gw2.plus.net [212.159.1.58]
  5    44 ms    44 ms    43 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
  6    43 ms    43 ms    43 ms  212.58.238.133
  7    43 ms    43 ms    42 ms  virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
Any advice would be most welcome
cheers
Roy
52 REPLIES 52
SparckZero
Re: High pings
ryoken,
Are you connecting wirelessly to your router, or via an ethernet cable? Looking at the ping times to your router, I would say it's wireless...
James
Re: High pings
Your traceroute looks absolutely fine.
The only delay is the first hop to your router, which is perfectly normal.
What do you see when doing a traceroute to one of the servers that you use?
ryoken
Re: High pings
Nope wired  Sad
ryoken
Re: High pings
Have no idea how to trace route to just an ip .
At the moment the pings to the ip addy look fine but during the evening pings go mental and I'm usually kicked for high ping
James
Re: High pings
You just type the IP address instead.
For example: tracert 232.163.75.32
(I just made that one up :p)
ryoken
Re: High pings
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\ROY>tracert 81.19.217.152
Tracing route to server.directclanhosting.com [81.19.217.152]
  1    8 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    42 ms    47 ms    43 ms  lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
  3    43 ms    43 ms    44 ms  vl604.thn-gw1.plus.net [84.92.4.169]
  4  127 ms    42 ms    44 ms  ae0-102.ptn-gw01.plus.net [212.159.1.53]
  5    43 ms    44 ms    42 ms  vl31.ptn-gw02.plus.net [195.166.129.2]
  6    43 ms  124 ms    43 ms  ae0-461.rt0.sov.uk.goscomb.net [195.66.226.226]
  7    43 ms    43 ms    42 ms  ae0-1624.rt2.the.uk.goscomb.net [77.75.109.161]
  8    43 ms    42 ms    44 ms  tele-north.killercreation.co.uk [77.75.109.198]
  9    47 ms    47 ms    47 ms  217.146.94.6 [217.146.94.6]
10    47 ms    46 ms    46 ms  server.directclanhosting.com [81.19.217.152]
James
Re: High pings
Okay, that still looks fine.
Try doing a traceroute when you're having problems and also try pinging the IP address directly.
Oldjim
Resting Legend
Fixes: 63
Re: High pings
without checking - I think that is the Ellacoya step which has the higher ping
ryoken
Re: High pings
No problem ,it wont be until later tonight .
Is there a way to trace to a certain port as every time i try it fails.
Grin said i was a doof
got router info here
DSL Connection
Link Information
Uptime: 14 days, 14:30:12
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 14.0 / 25.0
SN Margin (Up/Down) [dB]: 23.0 / 6.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 8 / 526,498
CRC Errors (Up/Down): 8 / 90
HEC Errors (Up/Down): 2 / 81
dont know if that helps
cheers
ryoken
Re: High pings
Sorry I've not been able to get on the last couple of nights(work >:()
It seems the problem is on certain ports.we run four servers (same ip different ports) two servers are fine but at night my pings can reach over 4000ms Shocked
No one else seems to have problems so i take it its something my end.
ryoken
Re: High pings
Tonights pings are hitting around 170ms
  1    11 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    64 ms    59 ms    70 ms  lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
  3    51 ms    47 ms    48 ms  vl703.thn-gw2.plus.net [84.92.4.242]
  4    55 ms    55 ms    60 ms  vl23.pte-gw2.plus.net [212.159.4.28]
  5    63 ms    87 ms    82 ms  ae0-1234.rt2.the.uk.goscomb.net [195.66.224.226]
  6    59 ms    53 ms    61 ms  tele-north.killercreation.co.uk [77.75.109.198]
  7    61 ms    57 ms    67 ms  217.146.94.6 [217.146.94.6]
  8    56 ms    57 ms    53 ms  server.directclanhosting.com [81.19.217.152]
ryoken
Re: High pings
Thought i had better do a bbc one as well
  1    7 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    49 ms    54 ms    52 ms  lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
  3    67 ms  103 ms    56 ms  vl703.thn-gw2.plus.net [84.92.4.242]
  4    53 ms    69 ms    48 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
  5    48 ms    49 ms    85 ms  212.58.238.149
  6    50 ms    50 ms    50 ms  virtual-vip.thdo.bbc.co.uk [212.58.224.138]
ryoken
Re: High pings
Tonight is realy bad over 700ms Cry
  1    65 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    60 ms    64 ms    67 ms  lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
  3  202 ms  184 ms  218 ms  vl703.thn-gw2.plus.net [84.92.4.242]
  4    55 ms    57 ms    74 ms  vl23.pte-gw2.plus.net [212.159.4.28]
  5    76 ms    54 ms    56 ms  ae0-1234.rt2.the.uk.goscomb.net [195.66.224.226
  6    55 ms    49 ms    54 ms  tele-north.killercreation.co.uk [77.75.109.198]
  7    60 ms    51 ms    59 ms  217.146.94.6 [217.146.94.6]
  8    59 ms    72 ms    56 ms  server.directclanhosting.com [81.19.217.152]
Trace complete.
C:\Users\ROY>
I am at a loss now
zubel
Re: High pings
Sounds like time for a wireshark capture
My guess is that the non-standard ports are not being classified correctly by the Ellacoyas.
B.
