High pings with interleaving disabled
- High pings with interleaving disabled
01-07-2009 9:47 PM
2 37 ms 37 ms 43 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 38 ms 51 ms 45 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 39 ms 39 ms 37 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 38 ms 37 ms 39 ms vl23.pte-gw2.plus.net [212.159.4.28]
6 45 ms 43 ms 43 ms 92.core.plus.net [212.159.1.92]
7 45 ms 43 ms 45 ms fhw-lb04.plus.net [212.159.1.146]
8 45 ms 46 ms 43 ms portal.plus.net [212.159.9.2]
Interleaving has been disabled yet ping's do not seem to be any lower.
I'm currently on Value and thinking about upgrading to unlimited.
Re: High pings with interleaving disabled
01-07-2009 9:53 PM
01-07-2009 10:12 PM
01-07-2009 10:41 PM
02-07-2009 2:51 AM
if you look at the line stats on your router does it say interleave depth with a value after it or fast.
could all ways try DMT or routerstats to see if interleaving is on or off then you have a pieace of paper with the eveidnce to wave in BTw smug face
02-07-2009 10:05 AM
If you look at your traceroute, the first hop to your router seems rather high.
Are you sure that you weren't doing anything with your internet connection at the same time as running that traceroute?
02-07-2009 10:43 AM
Quote from: ASBO what router are you runing comocon.
Product Name: TG585 v7
Software Release: 7.4.4.7
I tried DMT but it wouldn't work due to the version of the router firmware. I can't see anything about interleaving in RouterStats.
Quote from: Jameseh If you look at your traceroute, the first hop to your router seems rather high.
99ms at the first hop is common in SpeedTouch routers. The connection was idle when I ran the traceroute.
02-07-2009 10:51 AM
All Speedtouch routers have a high first hop - doesn't actually mean anything
Quote from: Jameseh Hiya,
02-07-2009 10:53 AM
I'll get it turned off for tomorrow morning. Sorry about that!
02-07-2009 4:51 PM
[Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum Rules]
