High ping & jitter
Scottonpc
High ping & jitter
High ping 60ms+ and jitter 20ms+ which has been occuring in the mornings this week and improves in the afternoon. I have restarted the router and the ping and jitter are still the same
1 REPLY 1
Scottonpc
Re: High ping & jitter
Uptime: 0 days, 1:38:49
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.259 / 21.562
Data Transferred (Sent/Received) [MB/MB]: 738,47 / 256,34
Output Power (Up/Down) [dBm]: 11,9 / 0,0
Line Attenuation (Up/Down) [dB]: 9,8 / 21,5
SN Margin (Up/Down) [dB]: 6,9 / 3,5
Loss of Link (Remote): -
Error Seconds (Local/Remote): 43 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 309
HEC Errors (Up/Down): 0 / 997
