High loss of signal figure
- High loss of signal figure
18-05-2012 10:15 AM
Uptime: 0 days, 4:29:41
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 576 / 15,012
Bandwidth (Up/Down) [kbps/kbps]: 440 / 9,592
Data Transferred (Sent/Received) [MB/MB]: 3.35 / 27.96
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 16.5 / 30.0
SN Margin (Up/Down) [dB]: 13.5 / 12.0
Loss of Signal (Local/Remote): 65,536 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 851,958 / 0
FEC Errors (Up/Down): 15 / 33,023
CRC Errors (Up/Down): 102 / 189
HEC Errors (Up/Down): 14 / 6,778
Normal figures are :
Maximum Bandwidth (Up/Down) [kbps/kbps]: 776 / 14,496 Bandwidth (Up/Down) [kbps/kbps]: 440 / 13,432 with SN margin down of 3 and loss of signal local ~ 2.
Is this my Thomson router giving weird figures or is there a problem? The router is plugged into the main socket.
Thanks for any info.
Re: High loss of signal figure
18-05-2012 11:46 AM
Maybe a Plusnet DC team member could have a look at your connection history as well.
18-05-2012 1:24 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13373437403251.png" />
I would say that's the start of an intermittent connection issue that's slowed since the lowering of the profile. Probably worth running through the wizard at http://faults.plus.net and our faults agents will get it sorted for you.
18-05-2012 1:31 PM
Planned BT Network Maintenance - Friday 18th May Midnight-6.00am
...seems a likely culprit.
cheers
Graham
18-05-2012 2:31 PM
18-05-2012 2:46 PM
Uptime: 0 days, 9:09:07
Maximum Bandwidth (Up/Down) [kbps/kbps]: 576 / 14,976
Data Transferred (Sent/Received) [MB/MB]: 13.57 / 122.48
FEC Errors (Up/Down): 15 / 45,137
CRC Errors (Up/Down): 102 / 225
HEC Errors (Up/Down): 14 / 7,594
Normally connection seems to drop for about a minute every 4 - 5 days. However recently it has been reconnecting at a lower speed which has been cured by going into the router and disconnecting and reconnecting once but the SN margin has been staying at 3. Just over a month ago on the 10th April I had a few disconnections in quick succession and the SN margin rose and the slower speed stayed for about a week. Hope it is not an intermittent fault as they never happen when you want them to. Will raise a fault on Monday if more connection drops.
Thinking back I had a phone call last night about 9-00 and there was noise on the line but I know the caller has had problems so thought it was his line. Phone seems fine now and I've tried a quiet line test with a corded phone which was OK.
18-05-2012 2:54 PM
18-05-2012 11:07 PM
Remember copper is sensitive to electromagnetic interference, don't run it near power or anything of that sort. Make sure your wiring is not loose in your socket.
19-05-2012 9:09 AM
19-05-2012 11:15 AM
not lost connection overnight so if (as seems likely) it is an intermittent fault and happens again I will go through the faults wizard suggested by Matt. I guess that if the line remains stable then the SN margin will drop and the speed increase.
This morning the router stats show -
Uptime: 1 day, 6:10:15
Maximum Bandwidth (Up/Down) [kbps/kbps]: 576 / 15,032
Data Transferred (Sent/Received) [MB/MB]: 66.39 / 901.63
SN Margin (Up/Down) [dB]: 14.0 / 12.0
Error Seconds (Local/Remote): 851,962 / 0
FEC Errors (Up/Down): 15 / 97,339
CRC Errors (Up/Down): 102 / 562
HEC Errors (Up/Down): 14 / 30,759
19-05-2012 11:38 AM
19-05-2012 3:27 PM
Easiest thing to do is contact your phone line service provider, get them to check the line for noise. If it requires an engineer to visit after testing, that's what needs to be done... I can see that the line isn't in a perfect state so just get in touch and they should be able to help you out.
19-05-2012 3:35 PM
