High latency when uploading - fibre
- Re: High latency when uploading - fibre
09-07-2014 6:20 PM
Hi
Recently I have started noticing that whenever our internet connection is being used to upload (video, twitch, large files) that the latency spikes massively.
There is no drop in download speed but the ping increases by around 150
Example
BEFORE:
<a href="http://www.speedtest.net/my-result/3614282290"><img src="http://www.speedtest.net/result/3614282290.png" /></a>
WHEN UPLOADING:
<a href="http://www.speedtest.net/my-result/3614276345"><img src="http://www.speedtest.net/result/3614276345.png" /></a>
Any reason for this?
On FTTC by the way
Example
BEFORE:
WHEN UPLOADING:
On FTTC by the way
Message 1 of 7
(1,455 Views)
6 REPLIES 6
09-07-2014 7:04 PM
Yes, you're uploading. That's why you have a high latency.
Message 2 of 7
(1,005 Views)
09-07-2014 11:30 PM
but this didn't use to be the case? only started happening recently
Message 3 of 7
(1,005 Views)
10-07-2014 9:07 AM
It depends how much of your upstream you're utilising. If you're pretty much maxing out your upload, it'll cause high latency. If you're using your upload on P2P software, there is usually a way that you can cap how much of your upstream is being used.
Message 4 of 7
(1,005 Views)
10-07-2014 9:22 AM
Oh right I see. Is this just a case of not noticing it before? I upload to twitch and youtube mostly and these to tend to max out my upload.
Whats the technical reason behind higher pings? (just interested)
Message 5 of 7
(1,005 Views)
10-07-2014 9:55 AM
I'm trying to find the best way to explain how this works...
I found this explanation quite a good one http://superuser.com/a/701238
Message 6 of 7
(1,005 Views)
10-07-2014 12:56 PM
ah that does make sense. Guess I have just never noticed it before!
Thanks for the link
Thanks for the link
Message 7 of 7
(1,005 Views)
