High latency and UDP drops
cvine
Over the last few days I have been experiencing high levels of dropping of udp packets (and quite probably tcp as well) which makes DNS resolution when web browsing a matter of chance, together very high latencies.  I assume the two problems are linked.
Just at the moment the service is now practically unusable.
I cannot be the only one experiencing this.  Is anything being done about it?
Chris
scootie
Re: High latency and UDP drops
can you run some traceroutes please to give us an idea where the packetloss is happening?
cvine
traceroute to 212.159.6.9 (212.159.6.9), 30 hops max, 38 byte packets
1  192.168.2.1 (192.168.2.1)  3.991 ms  4.205 ms  2.231 ms
2  195.166.128.27 (195.166.128.27)  29.246 ms  35.452 ms  114.764 ms
3  gi1-2-803.pcl-gw1.plus.net (84.92.5.57)  31.542 ms  40.555 ms  79.121 ms
4  * * *
5  * * *
6  * * *
traceroute to bbc.co.uk (212.58.224.13Cool, 30 hops max, 38 byte packets
1  192.168.2.1 (192.168.2.1)  2.193 ms  2.104 ms  1.822 ms
2  lo0-plusnet.pcl-ag01.plus.net (195.166.128.27)  61.040 ms  62.020 ms  35.056 ms
3  gi1-2-803.pcl-gw1.plus.net (84.92.5.57)  90.677 ms  29.512 ms  31.808 ms
4  te2-1.pcl-gw02.plus.net (212.159.1.114)  30.581 ms  35.414 ms  30.395 ms
5  te2-2.thn-gw2.plus.net (212.159.0.190)  66.658 ms  133.434 ms  37.876 ms
6  rt0.thdo.bbc.co.uk (212.58.239.25)  30.922 ms  29.103 ms  29.047 ms
7  212.58.238.149 (212.58.238.149)  53.931 ms  27.879 ms  33.138 ms
8  * * *
9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
traceroute to portal.plus.net (212.159.9.2), 30 hops max, 38 byte packets
1  192.168.2.1 (192.168.2.1)  2.204 ms  3.073 ms  2.036 ms
2  lo0-plusnet.pcl-ag01.plus.net (195.166.128.27)  41.605 ms  29.202 ms  47.028 ms
3  gi1-2-803.pcl-gw1.plus.net (84.92.5.57)  30.842 ms  38.075 ms  36.708 ms
4  gi5-8.ptp-cr01.plus.net (84.93.224.4Cool  34.012 ms  66.086 ms  78.659 ms
5  vlan2658.ptp-elb02.plus.net (84.93.224.45)  38.621 ms  59.330 ms  35.946 ms
6  vlan2658.ptp-elb02.plus.net (84.93.224.45)  43.539 ms  48.441 ms  41.175 ms
cvine
And the secondary DNS server is just as bad:
traceroute to 212.159.6.10 (212.159.6.10), 30 hops max, 38 byte packets
1  192.168.2.1 (192.168.2.1)  3.253 ms  4.074 ms  2.065 ms
2  195.166.128.27 (195.166.128.27)  37.210 ms  61.384 ms  82.819 ms
3  84.92.5.57 (84.92.5.57)  38.821 ms  31.149 ms  35.381 ms
4  * * *
5  * * *
6  * * *
7  * * *
8  * * *
9  * * *
10  * * *
Fixes: 21
I'm surprised Bob hasn't spotted this,  probably because Feedback isn't the right Board.
cvine
I managed to resolve the problem by switching off the router and then reconnecting, so as to get a new IP address.
Chris
Fixes: 10
I don't like the times on some of the first hops to your router - you're on wireless aren't you?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
