High Pings to anywhere
- Re: High Pings to anywhere
12-09-2013 10:18 PM
Hi Plus,
I am encountering problems with my line. Once I've finished something online intensive (YouTube/Multiplay Gaming/iPlayer) all ping times increase to around 800/900ms for around 2/3hours.
I feel its a routing issue more then anything device/virus/software issue.
It is intermittent but bloody annoying.
To conclude nothing is downloading, nothing is updating, My PC is the only machine connected and I know thats secure. This is happening constantly and unfortunately not sure where to report such a issue.
I have also included trace-route / ping in this post.
I have tried:
Rebooting my router
Tried plugging the router in the master socket,
Tried different brand of routers and all of them get the same.
Rebooting PC etc.. all the common stuff.
Thanks.
I have tried:
Rebooting my router
Tracing route to google.com [173.194.41.136]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 1521 ms 1551 ms 1502 ms lo0-central10.ptn-ag03.plus.net [195.166.128.192
3 830 ms 905 ms 835 ms link-b-central10.ptn-gw02.plus.net [212.159.2.13
8]
4 724 ms 733 ms 638 ms 110.core.access.plus.net [212.159.0.110]
5 529 ms 506 ms 588 ms 72.14.223.32
6 542 ms 460 ms 457 ms 209.85.252.186
7 614 ms 496 ms 433 ms 72.14.238.55
8 331 ms 278 ms 339 ms lhr08s03-in-f8.1e100.net [173.194.41.136]
Trace complete.
Pinging google.com [173.194.41.136] with 32 bytes of data:
Reply from 173.194.41.136: bytes=32 time=159ms TTL=57
Reply from 173.194.41.136: bytes=32 time=131ms TTL=57
Reply from 173.194.41.136: bytes=32 time=172ms TTL=57
Reply from 173.194.41.136: bytes=32 time=180ms TTL=57
Reply from 173.194.41.136: bytes=32 time=16ms TTL=57
Reply from 173.194.41.136: bytes=32 time=12ms TTL=57
Reply from 173.194.41.136: bytes=32 time=13ms TTL=57
Reply from 173.194.41.136: bytes=32 time=163ms TTL=57
Reply from 173.194.41.136: bytes=32 time=329ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1283ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1295ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1529ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1033ms TTL=57
Reply from 173.194.41.136: bytes=32 time=938ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1355ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1382ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1373ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1438ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1521ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1556ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1471ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1498ms TTL=57
Reply from 173.194.41.136: bytes=32 time=1565ms TTL=57
Upstream: 445
Downstream: 7123
SNR Margin (Upstream): 26.6
SNR Margin (Downstream): 4.8
Line Attenuation (Upstream): 21.9
Line Attenuation (Downstream): 35.5
Thanks.
Message 1 of 5
(1,289 Views)
4 REPLIES 4
12-09-2013 11:09 PM
Are you connected via Ethernet or wireless?
Message 2 of 5
(533 Views)
13-09-2013 7:27 PM
Fully Ethernet.
Message 3 of 5
(533 Views)
16-09-2013 2:42 PM
Sounds very odd. I think the best thing to do would be to try a wireshark capture when things are running slowly - ideally if you could start the capture just before you finish your gaming/streaming or whatever so we get the start of the issue in the file generated that should give us all we need.
There's details on how to do that here: http://community.plus.net/library/faults/using-wireshark-for-data-capture/
If you could save the pcap file and zip it then attach it to a ticket we'll investigate for you and see if we can find out (and sort!) whatever's going on.
Message 4 of 5
(533 Views)
16-09-2013 9:08 PM
Yaroze,
Just a thought: what OS are you on? And do you have Orbit Downloader installed?
I ask because I was getting terrible problems a few months back with a choked-up connection, which disappeared once I'd uninstalled Orbit (I'm on Windows 7).
Message 5 of 5
(533 Views)
