High Ping & Static IP Trouble
- High Ping & Static IP Trouble
15-09-2013 8:56 PM
Hello,
I seem to be getting high pings of 30+ lowest I've had is 29 it seems a bit high to me, especially being on the Unlimited Fibre package. Also I seem to be having trouble with assigning the Static IP to my PC, could anyone please help me?
Thanks!
Thanks!
Message 1 of 4
(770 Views)
3 REPLIES 3
Re: High Ping & Static IP Trouble
16-09-2013 12:15 AM
It's difficult to determine if a ping of 30 is high, without knowing who you're pinging. In the grand scheme of things on the Internet, 30 is quite low.
With the static IP (assuming it's the one from Plusnet), that is normally assigned to your router. To assign it to your PC would require playing with bridged mode, and all the issues that introduces.
Message 2 of 4
(431 Views)
16-09-2013 11:54 AM
Thanks for the reply, I sorted the Static IP out now The ping on anything I do is high, just a few months back it was 11 and below, even on Broadband I was getting 15.
Message 3 of 4
(431 Views)
16-09-2013 4:38 PM
Is it affecting your connection? If so, please post some ping results to servers that you use/play on along with maybe a traceroute to the same server - that should show us where the slow hops are.
Message 4 of 4
(431 Views)
