High Latency since lastnight
- High Latency since lastnight
14-02-2014 7:57 AM
Since last night I've been getting incredibly high latency on my broadband connection making it impossible to play online games, making website browsing slow and streaming intermittent. World of Warcraft was running between 1k-7k latency consistently throughout the evening until I gave up.
BBC Iplayer would play but occasionally stop telling me I didn't have enough bandwidth... upon refresh it would work fine again for 10-15 minutes.
Link Information
Uptime: 0 days, 0:30:52
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 14,247
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 13.5 / 26.5
SN Margin (Up/Down) [dB]: 29.5 / 4.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): NA / 361,016
CRC Errors (Up/Down): NA / 15
HEC Errors (Up/Down): 0 / 14
The down SN Margin started at a heady 3.5 after i reset the router.
The IP Profile BT test gives me an error.
The full speed test gives
Download 10.5
Upload 0.08
Latency 128.13
And the estimated line speed is...
Estimated line speed:
Current line speed:
12.4 Mb
I cant test the test socket as I don't have one (new build house with... what i think is an External NTL?) however the router is plugged into the first socket in the chain upon entering the house.
A tracert to google...
Tracing route to www.google.com [74.125.195.99]
over a maximum of 30 hops:
1 97 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 34 ms 50 ms 49 ms lo0-central10.ptn-ag02.plus.net [195.166.128.191
3 72 ms 62 ms 69 ms link-a-central10.ptn-gw01.plus.net [212.159.2.13
2]
4 115 ms 75 ms 69 ms xe-1-2-0.ptw-cr01.plus.net [212.159.0.112]
5 96 ms 93 ms 66 ms 72.14.222.97
6 80 ms 70 ms 64 ms 209.85.246.244
7 69 ms 53 ms 78 ms 209.85.245.2
8 71 ms 94 ms 75 ms 66.249.95.173
9 89 ms 69 ms 87 ms 209.85.250.161
10 * * * Request timed out.
11 71 ms 68 ms 65 ms wj-in-f99.1e100.net [74.125.195.99]
Trace complete.
Ping to the router...
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.1.254:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 2ms, Average = 1ms
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Dans>ping 192.168.1.254
Pinging the next hop...
Pinging 195.166.128.191 with 32 bytes of data:
Reply from 195.166.128.191: bytes=32 time=207ms TTL=126
Reply from 195.166.128.191: bytes=32 time=86ms TTL=126
Reply from 195.166.128.191: bytes=32 time=257ms TTL=126
Reply from 195.166.128.191: bytes=32 time=272ms TTL=126
Ping statistics for 195.166.128.191:
Minimum = 86ms, Maximum = 272ms, Average = 205ms
C:\Users\Dans>
Any help would be appriciated.
Regards
Link Information
Download 10.5
Upload 0.08
Latency 128.13
Current line speed:
12.4 Mb
2]
Trace complete.
C:\Users\Dans>
Regards
Message 1 of 5
(2,241 Views)
4 REPLIES 4
Re: High Latency since lastnight
14-02-2014 8:32 AM
looking at them stats PlusNET could kindly uncap the upload as it's currently set at 448, this should help with things. Hopefully staff will pick this up when they start work (9am ish)
Hopefully this may solve the problem, if not http://faults.plusnet.net would be the next option
Message 2 of 5
(527 Views)
14-02-2014 9:30 AM
This is my actual username... keep forgetting I have two.
Yes an uncap of the upload might help a bit, I've been meaning to ask about that for a while but not had any trouble so not really worked up the enthusiasm.
-Dan
-Dan
Message 3 of 5
(527 Views)
14-02-2014 10:15 AM
Hi Dan,
I've just got that order placed, that should complete by the end of the day on Monday for you. Please let us know f that improves things for you.
Message 4 of 5
(527 Views)
14-02-2014 12:41 PM
Thank you Chris,
Hopefully that will help, although the problem is quite frustrating it might just fix itself in the meantime, but will let you know if I continue having trouble.
-Dan
-Dan
Message 5 of 5
(527 Views)
