High Average Ping
- High Average Ping
High Average Ping
08-05-2019 7:45 PM
Heya,
Had an issue with ping spikes after moving into my new place about 5-6 months ago, thought I might be experiencing a similar issue, but it looks like it's a consistent high ping.
My average has jumped from 25-40ms up to 80-250ms - can I get a reset on my line to see if that sorts it?
Thanks!
Re: High Average Ping
08-05-2019 9:06 PM
09-05-2019 9:57 AM
Hi there.
I've tested your line today and I'm not finding any definitive issues with the broadband signal coming into your router.
The signal to noise ratio does appear to be moving around a bit, at this stage I'm not confident that this needs resetting.
Could you first check for any noise on your phone line by plugging a handset into your telephone socket?
