Hi Ping
- Re: Hi Ping
Hi Ping
22-01-2014 7:20 PM
Hi I am wondering if it possible to have something done to improve my ping to gaming servers. Servers that I am able to ping with my adsl service around 10ms I am getting ~40 with my firbre.
I can only assume interleaving or something is on.
Many thanks
Many thanks
Message 1 of 6
(843 Views)
5 REPLIES 5
Re: Hi Ping
22-01-2014 7:30 PM
Can you post a ping or traceroute to the gaming server? What are your pings like to bbc.co.uk ?
Message 2 of 6
(423 Views)
Re: Hi Ping
24-01-2014 8:41 AM
Thanks for the reply Andy. I will get some later today.
Cheers
Cheers
Message 3 of 6
(423 Views)
Re: Hi Ping
24-01-2014 5:05 PM
This is my ping to the bbc
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
>ping bbc.co.uk
Pinging bbc.co.uk [212.58.244.20] with 32 bytes of data:
Reply from 212.58.244.20: bytes=32 time=27ms TTL=55
Reply from 212.58.244.20: bytes=32 time=25ms TTL=55
Reply from 212.58.244.20: bytes=32 time=23ms TTL=55
Reply from 212.58.244.20: bytes=32 time=18ms TTL=55
Ping statistics for 212.58.244.20:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 18ms, Maximum = 27ms, Average = 23ms
This is to one the best server in bf4 ping wise
>ping 185.16.85.196
Pinging 185.16.85.196 with 32 bytes of data:
Reply from 185.16.85.196: bytes=32 time=24ms TTL=121
Reply from 185.16.85.196: bytes=32 time=22ms TTL=121
Reply from 185.16.85.196: bytes=32 time=30ms TTL=121
Reply from 185.16.85.196: bytes=32 time=28ms TTL=121
Ping statistics for 185.16.85.196:
Minimum = 22ms, Maximum = 30ms, Average = 26ms
These are roughly double what my adsl service is getting and double what my friends in the north east of England get on fibre.
I am assuming I have interlacing or something on my line.
Cheers
>ping bbc.co.uk
>ping 185.16.85.196
Cheers
Message 4 of 6
(423 Views)
Re: Hi Ping
24-01-2014 5:25 PM
These are my figures to the same IP Addresses, how ever I'm not a gamer and find my ping ok.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Kevin>ping 212.58.244.20
Pinging 212.58.244.20 with 32 bytes of data:
Reply from 212.58.244.20: bytes=32 time=20ms TTL=55
Reply from 212.58.244.20: bytes=32 time=19ms TTL=55
Minimum = 19ms, Maximum = 20ms, Average = 19ms
C:\Users\Kevin>ping 185.16.85.196
Reply from 185.16.85.196: bytes=32 time=20ms TTL=121
Reply from 185.16.85.196: bytes=32 time=21ms TTL=121
Minimum = 20ms, Maximum = 22ms, Average = 20ms
Message 5 of 6
(423 Views)
Re: Hi Ping
24-01-2014 6:45 PM
Hi Kevin
Thanks for the reply. My pings are not that bad but more or less double what I expected from 76 meg down and 18 up service. As I said my friends on fibre with karoo in Hull and one with bt in Scarborough are more or less half of what I am getting.
Message 6 of 6
(423 Views)
