Hg633 router on adsl
IanBa
I was hoping to use this dual band talk talk router. Just a matter of typing in the Plusnet account and password I thought...
Unfortunately, the router is not accepting changes to internet settings. I enter the credentials successfully. When I plugin the ADSL line, the user name reverts to 01warehouse☹️
Any ideas anyone?Huh
2u2me
Re: Hg633 router on adsl
IanBa
Yes I saw that. This refers to a VDSL fibre. My issue is that any changes I make in the router settings page are discarded when the router connects to broadband
2u2me
Then check out on`t web if anyone as had any success at flashing itSmiley
IanBa
Ok. Found solution myself.
Steps are
1. Disconnect adsl
2. Factory Reset router (paperclip method)
3. Logon to admin and amend internet user name and pwd
4. Press save and you will now see submitting dialog😎
5. Switch off. Connect ADSL. Switch on.😁
