Hg633 router on adsl
FIXEDTopic Options
- Re: Hg633 router on adsl
22-03-2018 10:45 AM
I was hoping to use this dual band talk talk router. Just a matter of typing in the Plusnet account and password I thought...
Unfortunately, the router is not accepting changes to internet settings. I enter the credentials successfully. When I plugin the ADSL line, the user name reverts to 01warehouse☹️
Any ideas anyone?
Any ideas anyone?
Fixed! Go to the fix.
Message 1 of 5
(1,331 Views)
4 REPLIES 4
22-03-2018 10:58 AM
Have a look at this :-
https://community.plus.net/t5/Broadband/Talk-Talk-Router-HG633/td-p/1353320
Message 2 of 5
(1,316 Views)
22-03-2018 11:06 AM
Yes I saw that. This refers to a VDSL fibre. My issue is that any changes I make in the router settings page are discarded when the router connects to broadband
Message 3 of 5
(1,308 Views)
22-03-2018 11:34 AM
Then check out on`t web if anyone as had any success at flashing it
Message 4 of 5
(1,294 Views)
22-03-2018 11:50 AM
Ok. Found solution myself.
Steps are
1. Disconnect adsl
2. Factory Reset router (paperclip method)
3. Logon to admin and amend internet user name and pwd
4. Press save and you will now see submitting dialog😎
5. Switch off. Connect ADSL. Switch on.😁
Steps are
1. Disconnect adsl
Message 5 of 5
(1,287 Views)
