Here we go again :-(
- Here we go again :-(
18-07-2013 8:25 PM
Oh dear. Connection starts well but then literally dies. Soooo many FEC errors.
Last latency was 1105ms.
Swapped filter back. Seemed ok but after 90 mins its unusable.
HELP
Re: Here we go again :-(
18-07-2013 8:53 PM
19-07-2013 8:11 AM
Can try a stand alone filter later on the test socket but weird it carped out with both :-S
19-07-2013 8:42 AM
I had the wrong (non USB enabled) firmware sent to my router (still have). Could this affect performance as the line stats (i.e. noise, SNR etc) look ok?
Can the correct 10.5?? firmware be sent?
19-07-2013 11:28 AM
You can get the latest firmware at http://products.plus-payh.co.uk/firmware/ to see if this helps. A guide on this can be found here.
20-07-2013 10:51 AM
Speed is all over the place. Had pings of 1105ms before, no upload speed at all and download speed is 1/2 of what it was 😞
Got FEC up load and down loads errors all over the place.
Not sure I'll be able to reflash to the firmware suggested as I'll be lucky to be able to download anything!!
Can my line be checked, please? This is the is starting to be like the problems I had 12 months ago and that was ridiculous!
21-07-2013 12:41 PM
New one on the way. Hope thats it.
21-07-2013 12:50 PM
21-07-2013 12:52 PM
22-07-2013 1:26 PM
22-07-2013 1:40 PM
22-07-2013 2:00 PM
22-07-2013 3:03 PM
The phone line seems fine, no noise or disconnections even when the ADSL is playing up.
Theres 2 wires connected to the BT Openreach face plate. Both look fine. The external master socket was disabled and bypassed by a BT engineer last year to make it internal when we had line issues last year.
22-07-2013 3:44 PM
22-07-2013 3:51 PM
It had dropped from 6.40mbps to 5.91mbps last night. Assuming its a dodgy router will this increase back again without intervention?
