Help
- Help
Help
20-04-2018 9:17 PM
I've recently moved house but my internet has very bad signal can't even get anything to load it's that bad
Re: Help
21-04-2018 8:58 AM
Welcome to the forums, @Delia
I'm afraid that without a little more detail there is little anyone in the community can do to help. Can you have a look at this topic and give as much detail as possible? https://community.plus.net/t5/Broadband/ADSL-Speed-faults/m-p/1270245#M297501
Re: Help
21-04-2018 3:32 PM
Hi @Delia, welcome to the forums.
I have had a look into this for you and testing isn't highlighting any issues and the speeds are within the estimates for you line.
Based on the length of your line, in all honesty the speeds aren't that great and is unlikely this will improve in the future.
Please let us know if there is anything more we can assist with.
Re: Help
21-04-2018 4:32 PM
Re: Help
21-04-2018 4:45 PM
I find it quite worrying that in response to a customer coming onto this forum and complaining that their connection is unusable that there is a response from a Plusnet staffer along the line "that's all you can get, tough" without considering whether there are any other factors in play such as the customer having a flaky wireless connection. @Delia, I can only suggest that you follow the advice of @jab1 and report the results.here for further advice as it's possible that your speed can be improved with a little self help.
Re: Help
21-04-2018 4:53 PM
@Delia It would be interesting and helpful to know what speed estimates you were given prior to your house move and how this compares with your actual speed at the moment.
Re: Help
22-04-2018 1:40 PM
@Delia Sorry to hear you're having issues.
Unfortunately our tests are showing your estimated line length from the cabinet to your property at 9 kilometres hence the poor speeds shown in our tests below
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 43.3 | 74.0 |
SNR Margin: | 4.9 | 6.9 |
Errored Seconds: | 12 | 2 |
HEC Errors: | 0 | |
Cell Count: | 0 | 0 |
Speed: | 792 | 967 |
Maximum Stable Rate (KBPS): | 2272 | Fault Threshold Rate (KBPS): | 2272 |
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 61 |
Indicative Line Quality: | G | Mean Time Between Errors Downstream (Seconds): | 595 |
Unfortunately as per @LaurenB reply above it's highly unlikely anything further can be done. We can look at getting a engineer out but due to the length of the line they will most likely not be able to do anything.
Re: Help
22-04-2018 1:45 PM
@MatthewWheeler Thanks for that further info - it does rather seem to be a 'length of line' problem, so asking the OP for further details seems a bit pointless.
Re: Help
22-04-2018 3:50 PM - edited 22-04-2018 4:46 PM
I'm sorry if I'm flogging a dead horse here. All we know is that the OP has a maximum stable rate of just over 2Mbps, we don't know if that's being achieved in a speed test.
Have you tried doing a speed test and if so are you getting a download speed of around 2Mbps?
EDIT
Ok so I've read this again and will show my ignorance of what it all means, I quote:
Speed: Upstream/Downstream DSL Link Information | 792 | 967 |
2272 |
The Max Stable Rate and Fault threshold are both 2272 Kbps, the Downstream DSL link is only 967Kbps; why is this acceptable?
Can some-one please explain.
Re: Help
22-04-2018 9:04 PM
@Baldrick1 - I think you may be onto something there - 967KBPS does look a bit below max stable.
Re: Help
23-04-2018 5:43 PM
Re: Help
23-04-2018 5:50 PM
I’m afraid it takes us back to here: https://community.plus.net/t5/Broadband/Help/m-p/1532996#M323027
We need to know more details.
Re: Help
24-04-2018 5:27 PM
Hi @Delia,
At this stage, before we proceed any further, I feel that it would be best to make sure that you getting the best possible speeds out of your connection. If you haven't already, I'd recommend following these trouble shooting guides to ensure you can receive the best possible throughput speeds within the property.
https://www.plus.net/help/broadband/connection-troubleshooting/
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Please let us know if this helps to improve anything within the property and if not we will have to look at getting an engineer out to evaluate whether or not anything further can be done to boost the speed along your line.
