Help
cydni2010
Help
Why oh why does my broadband keep dropping signal?Huh
I have done all the usual checks ie; cables etc but it is dropping every 5 to 10 mins its so frustrating!
Can anybody help please
1 REPLY
Fixes: 46
Re: Help
I've tested your line and it looks like there may be a fault causing this to happen.
I'd try following the checks here next: https://goo.gl/tu2WWu if you rule those out and it's still a problem then please report a fault over at http://faults.plus.net
Keep us posted.
 Adam Walker
