Help!!
- Help!!
Help!!
14-04-2015 6:25 PM
Hi Fellow Plusnetters,
Cut to the chase, My wife turned off the router about a week ago when we turned it back on it wouldn't boot up (its the technicolor White one)
the wireless light stayed red and we couldn't connect it was late so i left it till i got home from work the next day to sort it.
I had to stick a pin in the back and reset it ...it boot up perfect and everything is fine BUT my SNR seems to be stuck on 9 and not dropping back to 6
Which means i sync at 4800 and not 5800 as before ,
Can someone at pulsnet's end manually reset it for me ?
Message 1 of 3
(523 Views)
2 REPLIES 2
Re: Help!!
14-04-2015 7:34 PM
Message 2 of 3
(322 Views)
Re: Help!!
14-04-2015 8:56 PM
Thank you
Message 3 of 3
(322 Views)
