Help!!
- Help!!
Help!!
24-11-2014 11:51 AM
Now been signed up since Nov 5th and my download speed has never been greater than 1.7 mb I was told it would be 7mb and vary between 4.75 and 11 so why have I not been any ware near this?
I had logged a ticket on Saturday no reply yet, Gave up on phone as told 30 min plus waiting time so thought I would register in the hope that answer may follow quicker.
Also what is Technicolor TG582n ? have never been able to log in as it will not accept user name and password.
All in all not a good start.
Regards
Re: Help!!
24-11-2014 11:59 AM
Re: Help!!
24-11-2014 11:59 AM
Having done that can you post the information requested here http://community.plus.net/forum/index.php/topic,96155.0.html
If you have lost the card the login should be
User: admin
Password; Router Serial Number
Note that they are case sensitive
Re: Help!!
24-11-2014 12:10 PM
Quote from: Chris Your line is dropping a lot and is much slower than I'd expect. Can you make sure that your router is plugged into the master (test socket if possible) through a single filter and that all other sockets in use have a filter in place?
Did that on Saturday but still the same, I will add that we have 10 sockets throughout our Flat but only 1 is used all the time.
Regards
Re: Help!!
24-11-2014 12:15 PM
If you plug into the test socket - see http://community.plus.net/forum/index.php/topic,96155.0.html - are all the other sockets dead.
Is there any noise on the line - dial 17070 Option 2 - and is that there when using the test socket
Re: Help!!
24-11-2014 12:23 PM
Quote from: Oldjim To log into the router use the details given on the plastic card you received with the router under Router Access
User: admin
Hi, Thank you for prompt reply,
I assume that the username is the Name (ssid) and that the Password (Key) .
Regards
Re: Help!!
24-11-2014 12:31 PM
What you want is the Router Access underneath it
Re: Help!!
24-11-2014 12:31 PM
Quote from: Oldjim 10 sockets sounds nasty and may be part of the problem
Just tried and quiet no noise or hissing at all.
Re: Help!!
24-11-2014 12:41 PM
Quote from: Oldjim You are looking at the Wireless Network access
What I am looking at is the Your Wi-Fi setup detail card that was supplied and that is what I assumed you asked for in your 1st reply.
What I am now looking at under my router are the same details as for card but an additional PASSWORD SN & ROUTER PASSWORD STARTING WITH CP is this the one I have to enter?
Re: Help!!
24-11-2014 12:48 PM
Quote from: p147
UPDATE,
Just managed to register the router as for your instruction (under admin), Would have been a lot easier if they just simply would have printed the router password on the same card!!
Where do I go from here?
Regards
Re: Help!!
24-11-2014 1:25 PM
Once in go to
Broadband Connection
DSL Connection
Details (top left)
or go to http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0 to get straight there
We want this bit
Uptime: 27 days, 3:34:23
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 888 / 3,894
Data Transferred (Sent/Received) [GB/GB]: 2.17 / 20.98
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 26.8 / 50.0
SN Margin (Up/Down) [dB]: 9.3 / 6.1
When in the test socket can you confirm that all the other sockets are dead - connect a phone via a filter to check for a dial tone
Also when using any of the other sockets are you always using a filter
Re: Help!!
24-11-2014 4:46 PM
Can confirm first that details noy on my card with regards to router login, anyway the page I have got to and pasted the details below.
Uptime: 0 days, 4:15:24
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,107 / 2,091
Data Transferred (Sent/Received) [MB/GB]: 404.40 / 2.44
Hope this helps.
jim:quote
Re: Help!!
24-11-2014 4:54 PM
Re: Help!!
24-11-2014 4:55 PM
Quote from: Townman Nearly, but not quite - that is just the summary info, we need to see the full details please. Try here - http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0
Sorry.
DSL Connection
Link Information
Uptime: 0 days, 4:26:09
Data Transferred (Sent/Received) [MB/GB]: 406.46 / 2.45
Output Power (Up/Down) [dBm]: 12.4 / 0.0
Line Attenuation (Up/Down) [dB]: 23.1 / 42.0
SN Margin (Up/Down) [dB]: 6.1 / 2.3
Loss of Framing (Local/Remote): 61 / 0
Loss of Signal (Local/Remote): 7 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 7,027 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 153 / 819
HEC Errors (Up/Down): 89 / 334
Is this any better.
Re: Help!!
24-11-2014 5:03 PM
Can you please do the following as previously requested
Connect the router to the test socket
Check all the other extensions are dead
Report the full stats again
