Help with new install and loss of speed/disconnects
maria92
Hello, on 17th april got Fibre activated, first couple of day;s it was fine running at 55 mbps,
http://www.speedtest.net/my-result/3440268282
but  over the week's it has gotten worse and dc's randomly, and now its at
1. Best Effort Test:  -provides background information.
Download Speed
3.43 Mbps
0 Mbps 23.76 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.43 Mbps
For your connection, the acceptable range of speedsis 19.01 Mbps-23.76 Mbps .
Additional Information:
IP Profile for your line is - 23.76 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
6.08 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 6.08Mbps
also frequent disconnections,hopefully someone can check the line to see if there is fault,
EDIT: i have just checked the phone line again, and the line is very noisy, alot of crackling.
Fixes: 4
Re: Help with new install and loss of speed/disconnects
Hi 'maria92',  and welcome to the forum  Smiley
Try reading through these guides - Connection troubleshooting - Plusnet Fibre and Speed troubleshooting - Plusnet Fibre
but to be honest, if I were you, I would follow the Plusnet Brooadband Troubleshooter,  as this will collect all the information the fault investigation engineers require before they can help you - when they return to work on Tuesday.
Now you are on the forum, keep asking questions as there is always someone that will make a helpful suggestion  Wink
Fixes: 4
Quote from: maria92
You MUST get that noise fixed BEFORE trying to resolve broadband related problems !.
Is your PHONE service with Plusnet or another provider ?
You need to contact your phone service provider and report a noisy line, BUT if your phone service is NOT with Plusnet then don't mention that it is causing a broadband problem - as it is common for the phone provider to suddenly become uninterested in fixing the fault and blame your broadband provider (and vice-versa).
maria92
Hello, my phone provider is plus net, and have used the broadband troubleshooter, hopefully when they are back this problem will be fixed,
Fixes: 4
Perhaps you should also login to your account and Report a Telephone Fault, and answer the questions on that page.
roblightbody
Speaking from experience, until your phone line is completely clear (in all weathers), there's no point trying anything else.
I had 72mb+ for 2 years, until 5 weeks ago when my phone line started to crackle, now the line won't even stay up reliably, especially when its wet and windy.
