Help with a Home Hub 5 on ADSL - Line Stats
- Help with a Home Hub 5 on ADSL - Line Stats
19-03-2014 6:44 PM
I've just bought one via Ebay & although it seems to work OK, I can't seem to find any line stats (Signal/Noise ratio, attenuation etc) in the "Home Hub Manager".
The best I can find is under "Troubleshooting/Helpdesk" where it gives things like Uptime, 'Bandwidth' (no units given) - but no attenuation, SNR etc.
Having googled for information I found some suggestions that I should download "BT Desktop Helpdesk" - which was a waste of time since that insists on firing up Internet Explorer regardless of your preferred browser. Bad Software! Naughty!
So, can anyone throw some light on this?
Re: Help with a Home Hub 5 on ADSL - Line Stats
19-03-2014 6:58 PM
Which should auto-pool the line info
http://vwlowen.co.uk/RouterStatsHub/routerstatshub.htm
21-03-2014 1:14 AM
I downloaded Routerstatshub 5A & whilst it responded with all the data that the BT Home Hub Manager was inclined to give, data like SNR. Attenuation etc. all showed as zero (when it clearly shouldn't.
It starts to look as though BT have stopped collecting that data.
Drat and tish.
21-03-2014 10:16 AM
The website for the software says it works on ADSL too. Can't help you further I'm afraid.
21-03-2014 2:01 PM
21-03-2014 2:04 PM
I used my HH5 briefly on ADSL2+ before flipping to fibre. From my recollection the HH5 doesn't show stats like SNR etc for ADSL connections, but it does for Fibre.
Regards, David
21-03-2014 2:19 PM
21-03-2014 4:05 PM
21-03-2014 4:59 PM
Quote from: buseng12 This is all you get with a HH5 (on a fibre connection).
<Envy>
Here's what I get on ADSL
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 19/03/14
4. Board version: BT Hub 5A
5. ADSL uptime: 1 days, 15:38:02
6. Bandwidth: 1084 / 12513
7. Data sent/received: 40.2 MB / 577.1 MB
No atten, no SNR no units on that "Bandwidth" entry but I guess it might be upstream/downstream speeds.
Incidentally I scanned thorough the Event Log & can't even find any atten or SNR values in there.
21-03-2014 11:05 PM
Quote You can get a bit more than the basic info, but it's a bit of a faff...
Log in to the router and go to "Troubleshooting", choose "Event Log", and Category "WAN". You'll find something like this from the last time your line synched:
22:04:23, 09 Aug. ( 105.560000) DSL is up
22:04:22, 09 Aug. ( 104.640000) DSL noise margin: 5.90 dB upstream, 6.00 dB downstream
22:04:21, 09 Aug. ( 103.730000) DSL line rate: 1151 Kbps upstream, 14616 Kbps downstream
22-03-2014 7:17 PM
Quote from: jimbof I believe the following works:
Thanks, I tried that and there's no such data given - just mundane things like
01:16:46, 20 Mar. ( 196.810000) WAN operating mode is ADSL
01:16:46, 20 Mar. ( 196.800000) PPPoA is up - VPI: 0, VCI:38
01:16:45, 20 Mar. ( 196.000000) PPP IPCP Receive Configuration ACK
01:16:45, 20 Mar. ( 195.990000) PPP IPCP Send Configuration Request
01:16:45, 20 Mar. ( 195.980000) PPP IPCP Receive Configuration NAK
01:16:45, 20 Mar. ( 195.980000) PPP IPCP Send Configuration ACK
01:16:45, 20 Mar. ( 195.980000) PPP IPCP Receive Configuration Request
01:16:45, 20 Mar. ( 195.790000) PPP IPCP Send Configuration Request
etc
What does puzzle me, now that I look more closely is the occasional entry like this
01:16:33, 20 Mar. ( 184.540000) ETHoA is up - VPI: 0, VCI:35
why on earth would it change to VCI = 35 ?!?
