Help plz - fibre broadband running slow
mh68
Hello, on Sunday my router began disconnecting after about an hour`s internet use each time, and required restarting the hub each time to reconnect. The subsequent download connection speed went down to around 9mb/s. Although the connection has been disconnecting less since then, the speed has gradually been dropping even lower until today where it is now running at around 6mb/s download speed.
I have checked speeds using a wired connection between my laptop and the hub, and speeds are the same as a wireless connection. A speedtest using the link on the pinned post showed it was running at 6mb/s.
I am on an unlimited fibre broadband package, with the usual download speeds being around 30mb/s on my connection.
1 REPLY 1
Fixes: 480
Re: Help plz - fibre broadband running slow
Report a fault https://www.plus.net/help/report-a-problem/
