Help please
jaym0nd
Help please
Hi
I had Fibre Broadband installed 22/2/13 but over these past few days it just feels sluggish, what is going on here guys?
It was lightening fast up until say Monday 25/2/13
jaym0nd
Re: Help please
This is unacceptable.
jaym0nd
Re: Help please
What is going on?!
rongtw
Fixes: 12
Re: Help please
have you tried to switch gateways ?  some are bad at mo  Embarrassed  hopefully PN will sort it soon  Wink
log on  to your  router web page & disconect then reconect  you should then be on a different gateway  Cool
jaym0nd
Re: Help please
Sure doesn't feel as fast as it's reporting though... Undecided
Re: Help please
Hi jaym0nd,
Sorry to hear that you've experienced slow speeds, we've currently investigating this and we'll update you as soon as possible.
Chris
jaym0nd
Re: Help please
Hi
Yes it is still extremely sluggish, what is going on here guys?
My standard broadband at 5mb with Sky was faster than this.
Is it my profile?
jaym0nd
Re: Help please
Please just reset my speed profile
Re: Help please
When you say sluggish, can you elaborate?
What is your setup? Wired/wireless etc.?
Can you run the BT Speed Test (http://www.speedtester.bt.com/) and click "further diagnostics" and post all the results?
englishrick
Re: Help please
Quote from: jaym0nd
Your profile has been lowered as wellHuh?? SNAP!!
jaym0nd
Re: Help please
Come on Plus net raise my profile, I was at 78mb on the day of the Openreach guy here.
Bright
Re: Help please
So have you checked what your BT IP profile is set to?
Have you checked your Plusnet profile?
You've asked for a profile reset, but do you know whether it needs to be reset?
AndyH identified a test and some information that would allow other members here to try and help you. If you post that information, that may provide some useful clues about what is wrong...
englishrick
Re: Help please
BT Profile is set at 67.02 Mbps
Plusnet is set at 78 Mbps
jim:quote
Bright
Re: Help please
@englishrick
Sorry Rick, the question was aimed at  jaym0nd. I think your problems are covered in great deatil in a different thread Wink
