Help line for 85 year old
- Help line for 85 year old
05-05-2021 12:35 PM
Shocked to be told that as I don't have a PlusNet router you are not able to help me maintain my connection Is this the way you now go
Re: Help line for 85 year old
05-05-2021 1:26 PM
What is the router and what is the problem? I am sure one of us can help.
As a PN customer you will probably have a PN router not in use which could be a way to solve the problem. They are are not that bad as routers go!
05-05-2021 2:08 PM
05-05-2021 2:18 PM - edited 05-05-2021 2:18 PM
You cannot expect Plusnet front line agents to be familiar with every modem/router combination. They therefore offer a combined modem/router for the P&P charge. Many of us use an alternative but keep the original equipment should the need to call on Plusnet for help arises. These are perfectly adequate for fault finding up to the BT Master Socket, which is where Plusnet's responsibility ends.
If instead of just complaining you explain your problem here you might be surprised at the degree of help and advice that you will find offered by fellow customers.
05-05-2021 2:45 PM
@Baldrick1 have a whole chunk of history here Re: Please set me up like this again (year or so a... - Plusnet Community
05-05-2021 3:34 PM
In the past I have had plenty of good help and now expected some advice not just, oh its not our router we cant help, Nor a rap on the knuckles from "whoever" for casting my disappointment. I did explain my problem at the time and was phoned back. I have had to resort to help elsewhere The router is Netgear N 600 DGND3700v2 Which was given to me as the Plusnet ones hardly work here
05-05-2021 3:43 PM
I don't think that that router will work on FTTC if that is the problem. I had to ditch mine for the PN one and then a BT HH.
05-05-2021 4:02 PM
Thank you The router has worked for years it was given me by a Vodafone employee ,Previously I had a 2 wire one given me by a friendly BT engineer, The Plusnet ones were not as good It was a password problem I am trying to get gmail on my Thunderbird and must have changed the password on the router , how I dont know This has been sorted for me by another organisations employee Many thanks for your interest
05-05-2021 4:03 PM
What is FTTC
08-05-2021 10:58 AM
FTTC?
Fibre To The Cabinet. i.e. The usual version of optical fibre based broadband. Fibre from the exchange to your local cabinet (frequently an additional, auxiliary cabinet), then the usual copper wire from the cabinet to your property. Needs a router that handles the protocols used by FTTC.
As opposed to FTTP, Fibre To The Premises. Fibre all the way - from the exchange to cabinet, then from the cabinet to your premises.
I don't think Plusnet offer FTTP.
08-05-2021 12:25 PM - edited 08-05-2021 12:27 PM
Except that FTTP actually cuts out the middle man, that being the cabinet.
i.e. Fibre goes all the way from the the head-end (which may not be located in your local exchange) to the premises, via various nodes and splitters which are usually located in underground chambers. The chambers may or may not be located near cabinets, but the fibre doesn't touch the cabinets.
Edit: that's Openreaches implementation anyway.
08-05-2021 12:44 PM
I am at least 2 miles from the nearest cabinet and as you can see from my history,kindly published on here, have usually struggled to maintain a contact useable at just below 2
All help is appreciated as we are not all computer literate Thank you
09-05-2021 9:24 AM - edited 09-05-2021 9:26 AM
Have we established whether you are on ADSL or fibre (FTTC)?
Low quoted speed seems to imply ADSL but, if there is a fault...
09-05-2021 9:41 AM
Yes ASDL and am backi where I was now Thank you
19-05-2021 5:25 PM
Still not illumination of what the problem is and the help required - just a grumble that (understandably) Plusnet cannot offer help in respect of every router under the sun.
From the linked to topic, the user appears to be on the end of a very very long (rural ?) line which appears to be little better than wet string. No amount of router finessing on a 70dB line is likely to make a meaningful difference here.
What help is it that you seek here, or are you just wanting to vent a little?
