Help before renewing contract
Jcdek
I have been with Plusnet for many years now (Madasafish before that). My downstream connection sits at 3db and has done for a long time. The connection is stable and I never seem to have any problems with it until..........I renew my contract.
I then find my connection goes back to an SNR of 6db, I lose about 20meg download and I have to constantly argue with Plusnet until eventually somebody changes a setting and my speed it restored by a change back to SNR of 3db.
Is there any way I can prevent this from happening as I have grown tired of the fight every time I renew.
Thanks in advance.
8 REPLIES 8
Jcdek
Re: Help before renewing contract
Any Plusnet representatives care to comment?
Fixes: 387
It takes - on average - three days before a post is picked up by PN staff - sometimes longer.
Jcdek
Thanks John👍
Fixes: 1,662
Renewing a contract on the same package won't make any changes to your service. From what I can see the last time you renewed you upgraded from basic fibre to fibre extra, which would've triggered DLM to set the SNRM target back to 6dB.
It is not possible for anybody to manually change the SNRM target for a FTTC connection. Assuming you don't change package again, then renewing your contract won't make a change to your service. Smiley
Jcdek
Thanks for your reply,
I agree this is how it should work but not how it has done. Every time I have renewed my contract the same thing has happened. This is why I upgraded to Fibre Extra last year in the hope my speed wouldn't drop so much.
I should add also, every time the SNRM changed back to 3db I was told it was 'a setting change that needed to be made at Plusnets end' and each time I inquired what the setting was (so I could mention it the following when the same situation would most likely happen again) they wouldn't tell me.
I'll give Plusnet one more chance and renew again this year but if the same thing happens again and my SNRM goes back to 6 then I won't renew next time.
Fixes: 1,662
Hi @Jcdek,
Sorry I mean if you recontract on the same package then no changes are made to the service. There is also nothing we can do to manually change the SNRM target of a FTTC connection. We may try but ultimately it'd have no effect for FTTC.
I suspect the dB increased and then dropped out of coincidence rather than anything we've done to renew your contract.
Thanks for renewing! How's your speed today?
Jcdek
Speed still the same at the moment and I hope that doesn't change.
Thanks again for your responses.
Fixes: 1,662
Cool.  No problem, let me know if there’s anything else you’d need help with Smiley
