Help With Router
- Help With Router
Help With Router
25-12-2011 6:59 PM
Re: Help With Router
25-12-2011 7:34 PM
25-12-2011 7:44 PM
25-12-2011 7:59 PM
To be is to do - Kant
do be do be do - Sinatra
25-12-2011 8:04 PM
25-12-2011 8:15 PM
25-12-2011 8:24 PM
25-12-2011 8:52 PM
The "password" is given as the SN in the bottom right hand corner beginning CP**** remember admin all lower case
25-12-2011 9:09 PM
thanks again
25-12-2011 9:28 PM
192.168.1.254, is the local IP address of our routers. So yes, you should be able to access the router gateway using that address.
