Help Please - Bad Connection Since Returning From Holiday
- Help Please - Bad Connection Since Returning From ...
Re: Help Please - Bad Connection Since Returning From Holiday
22-08-2013 7:00 AM
@PlusNet, I keep getting re-sync events where my router will re-sync at about the same speed (around 18k) but there will be no loss of connection and nothing shows up in the router log. Following these I have no connectivity, (I can't ping past the router) and I have to disconnect/reconnect to get my connection back. This never happened before - are you sure that there is nothing wrong on the BT side?
Bob
22-08-2013 10:19 AM
When you had the issues were you connected to your master socket?
There's doesn't appear to be any issues with your line, with the information you've provided so far it seems to point towards the internal wiring side of things.
22-08-2013 10:51 AM
I can understand how my internal wiring might reduce my speed but why would it cause my router to resync and then be unable to access the Internet until I disconnected/reconnected?
Bob
22-08-2013 2:28 PM
22-08-2013 8:27 PM
I think I'm going to try the filtered faceplate and see if that fixes the problem.
Bob.
22-08-2013 8:42 PM
Do you really mean "Master Socket" or did you intend to say "Test Socket" ?
Or are you really saying that plugging your modem/router into the master socket faceplate, stops the phone extensions working ?
Out of interest, what telephone handsets are you using ?
22-08-2013 9:14 PM
We have old Binatone and Boots handsets plus a Siemens A580IP VoIP/DECT phone.
Bob
22-08-2013 9:24 PM
Then you could plug the A580IP base station into your new filtered master socket faceplate, along with your modem/router into the ADSL socket, and then you could completely eliminate the need for any phone extension wiring in your house.
Recently additional A580 handsets and charging bases have been selling on eBay for £9.99 in "nearly new" condition.
22-08-2013 9:40 PM
Bob.
22-08-2013 10:01 PM
If you choose the ADSLnation faceplate, you will need to connect the extension wires to the new faceplate.
With the VDSL Interstitial faceplate, then you don't need to reconnect the extension wiring.
I'm just trying to point out that the optimum setup would be to have no extension wiring, and questioning whether you had considered that possibility as a better long term solution, at a time when you are considering spending money on a new faceplate, etc.
22-08-2013 10:06 PM
22-08-2013 10:13 PM
Bob.
23-08-2013 9:37 AM
Bob
23-08-2013 4:41 PM
23-08-2013 5:14 PM
Bob.
