Help! End of my tether with BB connection
- Help! End of my tether with BB connection
15-10-2010 7:36 PM
Eventually yesterday someone at PN forced the SNR down to 6dB my router immediately disconnected and reconnected at 7700kbps - bliss!. However, it seems today there was another disconnection which has forced the SNR back up to 12dB and connection speed of 5271kbps. If the pattern follows I guess I'm going to get another random disconnection tomorrow, most likely forcing the SNR up again.
The frustrating thing is that apparently it can't be raised as a line fault as it's only one disconnection a day, but there must be something wrong for it not to be able to hold a stable line! The disconnection is also not at a constant time, I've had just before 6am I think. about 7am this morning, 11am yesterday morning, so I can't tie it to anything specific.
It's been in the test socket (i.e. the one behind the base plate) for about 4 days now, the only other thing that I can think is wrong is that there's a problem with the router itself (it's a PN supplied Thomson one). Before I swap it out for another router, does anyone have any other suggestions or is it possible that there is actually a line fault?
I'm going a bit !
Interestingly I've just rebooted the router and the SNR has gone back down to 6.5dB with connection speed at 7203, I just don't want the SNR to go back up again (strange that it did with the reconnection this morning and stranger that it's gone back down again!).
Re: Help! End of my tether with BB connection
15-10-2010 11:22 PM
To be honest I would raise it anyway if it's not you dropping the connection. I would expect more drops from a line fault but if it were to get worse at least you'll already have the ball rolling. I think it's more likely to be interference from something but that would just be a guess.
Jojo
16-10-2010 4:29 PM
I've raised it a number of times (there are plenty of closed tickets), I was only worried that if I raised it again it would just get closed again with "it's only disconnecting once a day so not a fault" which is what happened before. I'll raise it as you've said then.
17-10-2010 4:15 PM
17-10-2010 5:30 PM
Noise Margin: 17.0 dB
Bandwidth: 4544 kbps
Attenuation: 42.0 dB
Power: 19.5 dBm
Errors:
FEC: 0
CRC: 43
HEC: 13
Failures since last reset:
LOF: 12
LOS: 1
ES : 5
Can anyone interpret these results and let me know what the issues might be?
18-10-2010 9:56 AM
I've just ran a line test, the SNR is 16dB and this is definitely what's causing the lower sync speed. Are you in the test socket, Is there any chance that is could be caused by extensions or electrical equipment or anything else. I'm not sure what your set up is like.
Jojo
18-10-2010 6:29 PM
The line has been in the test socket for probably the last week (it's a pain in the bottom as it means the main phone is also downstairs and my HTPC connects to the router via cable so the box can't get any recording guide updates!). The line has actually been stable for the last 1 day and 2 hours now, I think that's the first time it's been stable for over a day in ages. To be honest I don't mind if the box disconnects once a day if the DLM maintains my 6dB target SNR, but at the moment it won't do that. I really want to move the router back upstairs now as it's proven to be no more stable in the test socket than it was upstairs next to the TV.
I don't know what causes the disconnect, or even what could cause it. It's definitely not something inside the house as it doesn't tie in with any electrical activity specifically. But then the disconnects are at random times, so don't coincide with any external influences either (weather, street lights etc). I know that there was an issue with our exchange a couple of days ago and the only thing I could think of is some exchange problem. 16dB should prove to be a rock solid line (as should 21dB!), the only other thought was a potential router issue? But then it has held lines at 3dB for 3-4 days before!
I think I'll move the router upstairs tomorrow regardless of any other issues and just hope the line will have been stable for a couple of days by then, maybe that'll indicate that the problem has mysteriously disappeared!
18-10-2010 11:16 PM
If you can leave it where it is for now and tomorrow I'll get the SNR put at 6dB and see how it goes from there. It's defintely the SNR keeping it low rather than the drops.
Jojo
19-10-2010 1:42 AM
19-10-2010 10:28 AM
Would you like me to go ahead with the SNR reset.
Jojo
19-10-2010 5:38 PM
What I really need is for someone to look at the ticket I raised, problem with not speaking to a person directly is that the tickets just get pushed into a queue and actioned as and when
20-10-2010 12:39 PM
your ticket has been updated. It's probably advisible to see how the interleaving goes before looking at the SNR reset.
Jojo
20-10-2010 3:33 PM
21-10-2010 4:07 PM
21-10-2010 5:09 PM
I think moving it probably did the damage Are you using an extension/extension cable?
Jojo
