Help - Edimax Router Set Up or General Problem?
- Help - Edimax Router Set Up or General Problem?
Re: Help - Edimax Router Set Up or General Problem?
29-12-2010 7:02 PM
30-12-2010 12:40 PM
Starting to seriously lose faith in plusnet, ticket is 2 days old and had no response from any staff, if this keeps up ill be sure to cancel and file a complaint.
Your turn around time/SLA shows 4hrs of an answer time on questions, current up to 8hrs. My ticket is now 48hrs old and all I have had is automated responses.
30-12-2010 12:49 PM
www.microsoft.com
www.speedtest.net
www.megavideos.com (although it resolves sometimes)
www.hotmail.com
30-12-2010 3:13 PM
Can you give us a list of the sites you can't resolve and trace routes to them.
Jojo
30-12-2010 3:16 PM
30-12-2010 3:22 PM
I Have ran trace routes and added them to the new ticket i had to opened.
Nslookup displays this:
Server: cdns01.plus.net
Address: 212.159.13.49
Non-authoritative answer:
Address: 66.114.124.140
websites i have issues with are Microsoft, megavideo, and speedtest.net - I have only found these 3 but im sure there wil be more
After running that nslookup i noticed its added underworld.com to the end of the address which i have no idea how or where its pulling that from as its my SSID is underworld
30-12-2010 3:28 PM
Quote from: Nemesis Non-authoritative answer:
Is this a copy of the result, because you have not spelt microsoft correctly there?
Jojo
30-12-2010 3:32 PM
C:\Users\Nemesis>nslookup microsoft.com
Addresses: 207.46.232.182
207.46.197.32
30-12-2010 3:38 PM
Pinging microsoft.com [207.46.232.182] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 207.46.232.182:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Trace Route:
Tracing route to microsoft.com [207.46.232.182]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 192.168.2.1
2 44 ms 46 ms 44 ms lo0-central2.pcl-ag04.plus.net [195.166.128.242]
3 43 ms 44 ms 42 ms gi1-12-421.pcl-gw01.plus.net [84.92.6.232]
4 43 ms 43 ms 42 ms po4.pcl-gw02.plus.net [212.159.1.129]
5 77 ms 45 ms 43 ms 195.50.122.129
6 43 ms 43 ms 43 ms ae-34-52.ebr2.London1.Level3.net [4.69.139.97]
7 112 ms 111 ms 112 ms ae-43-43.ebr1.NewYork1.Level3.net [4.69.137.74]
8 113 ms 112 ms 112 ms ae-4-4.ebr1.NewYork2.Level3.net [4.69.141.18]
9 112 ms 117 ms 113 ms ae-1-51.edge2.NewYork2.Level3.net [4.69.138.195]
10 110 ms 112 ms 111 ms MICROSOFT-C.edge2.NewYork2.Level3.net [4.71.190.
2]
11 112 ms 112 ms 112 ms 209.240.199.194
12 181 ms 180 ms 182 ms ge-7-0-0-0.co1-64c-1b.ntwk.msn.net [207.46.40.90
13 199 ms 197 ms 198 ms ge-0-1-0-0.wst-64cb-1b.ntwk.msn.net [207.46.43.1
85]
14 187 ms 187 ms 197 ms ge-4-3-0-0.tuk-64cb-1b.ntwk.msn.net [207.46.46.1
62]
15 185 ms 185 ms 187 ms ten1-1.tuk-76c-1b.ntwk.msn.net [207.46.46.21]
16 186 ms 184 ms 185 ms po15.tuk-65ns-mcs-1a.ntwk.msn.net [207.46.35.138
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 ^C
30-12-2010 3:41 PM
Tracing route to google.co.uk [173.194.37.104]
2 82 ms 44 ms 42 ms lo0-central2.pcl-ag04.plus.net [195.166.128.242]
3 44 ms 43 ms 43 ms gi1-12-421.pcl-gw01.plus.net [84.92.6.232]
4 45 ms 43 ms 43 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 43 ms 45 ms 43 ms po5.thn-gw1.plus.net [212.159.1.141]
6 43 ms 44 ms 43 ms po6.ptn-gw01.plus.net [212.159.1.137]
7 42 ms 42 ms 45 ms 72.14.223.32
8 46 ms 43 ms 43 ms 66.249.94.78
9 43 ms 43 ms 43 ms 209.85.251.202
10 270 ms 43 ms 43 ms lhr14s02-in-f104.1e100.net [173.194.37.104]
Trace complete.
30-12-2010 3:42 PM
Could possibly be MTU settings. Microsoft has been known to be affected by MTU settings. Have a look here for some further information.
Jojo
30-12-2010 3:44 PM
Pinging speedtest.net [74.209.160.10] with 32 bytes of data:
Reply from 74.209.160.10: bytes=32 time=186ms TTL=43
Reply from 74.209.160.10: bytes=32 time=187ms TTL=43
Ping statistics for 74.209.160.10:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 186ms, Maximum = 187ms, Average = 186ms
Speedtest used to work, just not now. also any way to chase up on gettin my IP Profile from BT?
Looking at MTU and RWin just now
30-12-2010 4:06 PM
Ran the tests and this is results,
RWIN is in range
Looking good
Observations:
Good data stream (no/few rexmits)
Your Tweakable Settings
Receive Window (RWIN): 338688
Window Scaling: 8
Path MTU Discovery: ON
RFC1323 Window Scaling: ON
RFC1323 Time Stamping: OFF
Selective Acks: ON
MSS requested: 1460
TTL: unknown
TTL remaining: 118
TOS/TOS subfield: 160
TOS/Flags:
Actual data bytes sent: 1026921
Actual data packets: 726
Max packet sent (MTU): 1500
Max packet recd (MTU): 1470
Retransmitted packets: 4
sacks you sent: 2
pushed data pkts: 40
data transmit time: 3.424 secs
our max idletime: 301.4 ms
transfer rate: 262013 bytes/sec
transfer rate: 2096 kbits/sec
transfer efficiency: 99%
My MTU within my router is set at 1492 - lowered it to 1470 and still no diffrence any other ideas?
30-12-2010 5:06 PM
www.get-someone-online.com
Tracing route to 213-199-186-27.itm.asp.msn.com.nsatc.net [213.199.186.27]
1 3 ms 1 ms 1 ms 192.168.2.1
2 54 ms 44 ms 44 ms lo0-central2.ptn-ag02.plus.net [195.166.128.206]
3 44 ms 43 ms 42 ms gi2-7-222.ptn-gw02.plus.net [84.92.5.147]
4 * 245 ms 240 ms igbtmdistc7503.msft.net [195.66.226.140]
5 43 ms 43 ms 42 ms ge-6-1-0-0.lts-64cb-1b.ntwk.msn.net [207.46.42.7
4]
6 54 ms 62 ms 53 ms xe-2-1-0-0.db3-96c-1b.ntwk.msn.net [207.46.43.18
7 53 ms 53 ms 54 ms ge-1-2-0-0.db2-64c-1b.ntwk.msn.net [207.46.42.28
10 * * * Request timed out.
11 * * * Request timed out.
seems to go haywire once its leaving your network ?
30-12-2010 6:54 PM
I have no issue with any of the sites you mention and yet all the trace routes you have shown us that fail, also fail for me. This like I say is normal and beyond PN's control.
