Hello, any help please?
- Hello, any help please?
20-10-2011 12:13 PM
I've been having difficulties with my modem for a few days, so I just reset it... Now the Internet light comes on, i thought great it's sorted.... But now! I get a pop-up screen saying i need to log in to get further... easy enough right? No.
It asks for my login name, i know it - no problem
password, i know it so again not a problem
BUT THEN; it asks for my service provider? Obviously PlusNet but it says to select the option from the drop down window, yet there's nothing in this window.
I cant advance until I've selected it, but ive turned my modem off & on numerous times, reloaded the IE pages numerous times... Any help? Thanks
Re: Hello, any help please?
20-10-2011 12:14 PM
20-10-2011 12:20 PM
i got it when applyin for this broadband
20-10-2011 12:25 PM
20-10-2011 12:36 PM
20-10-2011 12:37 PM
20-10-2011 12:40 PM
Free-online
F9
or PlusNet
20-10-2011 12:44 PM
1.Type 192.168.1.254 into a browser address bar
2. If prompted enter username: admin
Password: CP********* (found under a bar code on the underside of your router)
3. Click 'Thomson Gateway' in the left hand menu
4. In the main window under pick a task choose 'Set up my Thomson Gateway'
A window will open, just follow it through. When it asks for username type in username@plusdsl.net
After that it will prompt you to press start and after a couple of minutes you can click finish. It should then be configured within a minute or so.
Jojo
20-10-2011 1:37 PM
20-10-2011 5:38 PM
