Heavy usenet shaping
- Re: Heavy usenet shaping
02-09-2013 9:33 PM
Same nzb, same provider on another FTTC connection at 80/20 (with Zen) achieves a solid 8.2MB/s.
There is no other significant internet traffic on my connection at the time of testing and I am wired.
I thought there was no traffic management in place beyond prioritising traffic on a per-line basis?
02-09-2013 9:55 PM
It's more likely that the problem isn't Plusnet deliberately slowing down your usenet downloads because they don't have sufficient bandwidth. It could be some problem with the peering provider between Plusnet and the usenet provider, or maybe even something odd and unintentional going on with Plusnet's traffic management systems. Or the capacity at your exchange or in some part of the BTOR network.
03-09-2013 9:28 AM
Yes our capacity should be absolutely fine, though I've flagged this to Dave to have a look at - see what we come up with. Thanks very much for the heads up.
Guessing that was same number of threads and nothing else being used on the connection at the time?
03-09-2013 9:53 AM
Hope that helps.
03-09-2013 10:32 AM
Well done, Matt (and colleagues?).
Graham
03-09-2013 11:17 AM
05-09-2013 6:05 PM
I've just changed that, I was getting line speed previously but I guess we're not quite into the peak period, yet.
I shall keep an eye on it.
01-10-2013 8:30 PM
Started off at 1.6MB/s, not sure which GW.
Hopped, got AG02 and around 800K/s
Hopped again, got AG04 and now getting 1.7-6MB/s but averaging around 3MB/s.
02-10-2013 7:03 PM
02-10-2013 7:22 PM
03-10-2013 9:49 AM
Sorry about that, asked Dave to have a look but unfortunately the gateway hopping means that he couldn't find which endpoint you were on on the given gateway. If it happens again please don't drop the connection as that way we'll be able to diagnose it.
Has it happened again since?
03-10-2013 9:58 AM
I've not tried since, I will make more of an effort to try it throughout the evening over a few days and report back.
20-10-2013 7:37 PM
Not as bad as it has been - hovering around 4MB/s, but it has been down to sub 1MB/s.
20-10-2013 9:42 PM
21-10-2013 3:43 PM
