Hd a problem with my router, will it affect my sync?
- Hd a problem with my router, will it affect my syn...
21-12-2010 7:13 PM
Re: Hd a problem with my router, will it affect my sync?
21-12-2010 7:18 PM
21-12-2010 7:24 PM
Uptime: 0 days, 12:54:19
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 24,051 / 13,596
Bandwidth (Up/Down) [kbps/kbps]: 446 / 12,886
Data Transferred (Sent/Received) [GB/GB]: 26.57 / 2.17
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 13.0 / 23.0
SN Margin (Up/Down) [dB]: 25.5 / 14.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 12,550 / 58,214
CRC Errors (Up/Down): 294,668 / 76
HEC Errors (Up/Down): 234,489,202 / 621
by the look of it the line attenuation has gone up since using the plusnet router. it was sitting at half those values on the old one. would that make a difference?
21-12-2010 7:37 PM
Either wait for it to sort itself out (a few weeks) or ask for a noise margin reset - it's up to you
Having said that the errors look high - specially the upstream - so there may be another problem and a reset may not help as it will just bounce back in very short order
Have you tried the test socket to see if the error rate reduces or stays the same
You say that the router went pear shaped yesterday - it is possible that something else happened which caused noise problems on the line which appeared to be a router problem (Christmas lights for example)
21-12-2010 7:42 PM
21-12-2010 7:58 PM
21-12-2010 8:26 PM
Telephone number:
Phone exchange:
ALLOA
Estimated line speed:
8 - Checked on 2010-12-19 19:18:19
Current line speed:
Not set
Not happy with what thats saying... the estimated line speed we got when signing up was 15
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
6341 Kbps
0 Kbps 21000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 6341 Kbps
For your connection, the acceptable range of speedsis 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :12884 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 11000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 14.42:27.45:58.13 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
367 Kbps
0 Kbps 444 Kbps
>Upload speed achieved during the test was - 367 Kbps
Upstream Rate IP profile on your line is - 444 Kbps
21-12-2010 9:17 PM
Quote THE BROADBAND AVAILABILITY CHECKER
For Telephone Number ********** on Exchange ALLOA
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 8Mbps; typically the line speed would range between 7.128Mbps and 8Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 15Mbps; typically the line speed would range between 8Mbps and 19.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1.5Mbps and downstream line speed of 12Mbps; typically the downstream speed would range between 11Mbps and 13Mbps.
The actual stable line speed supportable will be determined during the first 10 days of use. This speed may change over time, to ensure line stability is maintained.
Thank you for your interest.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number check.
Note: If you already have a Broadband service enabled on this line and you want to switch service providers, you will need to contact both your current provider and your new provider to get your service changed over new and existing service provider to have this service transferred.
21-12-2010 9:19 PM
21-12-2010 9:25 PM
22-12-2010 12:26 AM
Quote from: jaxster . I was syncing between 15000-16000kbps but my router started going pearshaped yesterday and disconnected a few times in the space of a few hours
Were you aware that Plusnet were having serious problem and using the web yesterday was very very slow if not imposable?
So don’t bin your old router
Puddy
22-12-2010 2:13 AM
Quote from: jaxster Current line speed:
Not set
I've seen jojo respond to this before - I think it implies that PN will be letting less data through than your line can support - even now with the high SNR margin & relatively low speed.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
22-12-2010 7:34 AM
I was using newsgroups through the night and getting a max speed of eight meg. Like i said i was getting that with orange so I'd expect an increase after moving to adsl2+
22-12-2010 11:55 AM
22-12-2010 2:53 PM
The connection speed of 'not set' won't be helping. I'll get that sorted now.
Jojo
