Having problems with wifi connection
caroledp
 Having problems with wifi connection and broadband, had a fault on phone line which is now fixed but broadband is still shocking. Been going on for a few weeks now and don't know where to go next to sort it. Sick of being on hold to tech help for 45 mins at a time . Not in contract now so looking at changing maybe, but don't want to sign up to anything if its not going to sort the problem.
Gel
Seasoned Pro
Fixes: 14
Re: Having problems with wifi connection
Is it just wifi dropping, or is your router dropping broadband connection too; does your wired connection behave OK?
Have you tried changing wifi channel; yours may be in conflict with neighbour's router?
Fixes: 162
I can see that your line was disconnecting fairly frequently, however since Wednesday it's been a lot more stable. Did anything change at that point?
 Chris Parr
 Plusnet Staff
