Have to restart router nearly everyday
- Have to restart router nearly everyday
Re: Have to restart router nearly everyday
13-11-2021 4:58 PM
10-12-2021 9:04 AM
Hi coming back here as my problem still persists.
I have put in another fault request but have had no reply, I was told an engineer would be booked then that never happened as the fault had corrected itself, But obviously not.
This is getting so annoying where do I go from here?
10-12-2021 1:30 PM
Hiya @Frakesk, thanks for getting in touch. I am really sorry for the issues with your service and that your fault ticket was prematurely closed.
I have raised a new one here for you: https://www.plus.net/wizard/?p=view_question&id= 220322141 with the next steps in getting this progressed and if you reply with the requested information (and give us a nudge on here once done) we will get that picked up for you.
10-12-2021 8:30 PM
Unable to answer questions as comes up
There was an error
We were unable to access your ticket information.
10-12-2021 8:39 PM - edited 10-12-2021 8:40 PM
13-12-2021 1:18 PM
Thanks for getting back to us @Frakesk
It looks like the ticket ID wasn't included in the hyperlink above.
Try https://www.plus.net/wizard/?p=view_question&id=220322141 if @jab1's link doesn't work either
12-01-2022 9:28 AM
Hi, So following on from my previous post.
Engineer came checked everything out, replaced faceplate and did some work in the box in the street
Things have seemed better, but still have the wifi drop, so this morning whilst it was happening before restarting I ran a speed test 5 times
the results were
9,2 6,5
7,8 6.2
4.3 5.8
9.8 6.2
9.7 66
but lights were flashing all over and had to restart to reset
So my question is open reach have done all tests and replaced necessary does this fault lie with the router.
Many thanks
12-01-2022 4:34 PM - edited 12-01-2022 4:35 PM
Hello @Frakesk
Thanks a lot for getting in touch again. Can I ask, are the speeds you're getting there over a wired connection? I've tested the line this afternoon and all looks well from our end. The line appears to be syncing at above 12Mbps, and is for the most part quite stable. I'll pop a visual radius below, can you please have a look at it and let us know if the drops on there are consistent with you resetting the router?
12-01-2022 8:13 PM
Thanks for replying
No everything is wifi
Yes that is right for 12th and the 9th as all lights were flashing including wps which I have never seen flashing before.
thanks
kathy
12-01-2022 9:55 PM
EXACTLY what is / is not happening when you think is gone wrong? What do your devices report? Can they see the WiFi? Do they indicate if they are connected to the internet?
Do you know how to run the cmd prompt (are they windows devices)?
13-01-2022 4:32 PM
Thanks for getting back to us Kathy.
I'm really sorry to see you're still having connection issues.
Based on what we've tried so far and the engineers from Openreach and Qube we've sent out, I think the next logical step is to replace the router, so I've arranged to send you a new one free of charge now you should receive within 3 to 5 working days. It'll be more of an upgraded router of a better model than the Hub Zero you currently have.
Let us know how it goes once you've got it
13-01-2022 8:35 PM
the problems if not I give up 😁
14-01-2022 12:14 PM
I have just received an email saying I have a charge being added to my account
Kathy
14-01-2022 1:19 PM
03-02-2022 9:43 AM
Just an update
I have had the new router now for about 3 weeks and finally everything seems to have settled down, no more restarts
So fingers crossed
Kathy
