Have PN Updated ADSL Profiles??
- Have PN Updated ADSL Profiles??
06-10-2013 9:03 PM
Today I noticed that my router has synched at over 9Mbps. Thats significantly higher than I've ever seen it before. Its usually a little over 8Mbps. I also noticed that the SNR has also decreased to 3dB. This is lower than I've seen. i re-synched a few times and the router synched up with the same numbers.
So, is there a plan to reduce the noise margin in preference to higher synch speeds?
Message 1 of 3
(599 Views)
2 REPLIES 2
Re: Have PN Updated ADSL Profiles??
06-10-2013 9:44 PM
This is the automatic system in the exchange
You must be fortunate and have a line which will hold those speeds without to many errors or disconnections
The default noise margins set at the exchange are 3dB, 6dB, 9dB etc.
Message 2 of 3
(337 Views)
06-10-2013 10:11 PM
Thanks, that makes sense to me.
My line must have improved with age since I have been on 6dB for years and not changed a thing in the house at my end. Maybe its a fluke of the weather....?
Message 3 of 3
(337 Views)
