Have I been put onto the wrong product?
- Have I been put onto the wrong product?
22-03-2009 12:47 AM
I thought I'd been put on ADSL2+ because of the increased upload speed but there has been no improvement in download speed. However, my stats are similar (apart from mode and interleaving) to what's being discussed in that post. Could it be that I too have been moved to the wrong product? I was/am signed up for BBYW Option 2. Our exchange was only recently shown to be enabled though it was supposed to be done late last year.
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 1131 Kbps, Downstream rate = 4283 Kbps
Link Power State: L0
Mode: ADSL2
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 10.5 6.5
Attn(dB): 29.5 14.4
Pwr(dBm): 0.0 12.8
Max(Kbps): 5592 1144
Rate (Kbps): 4283 1131
G.dmt framing
K: 134(0) 35
R: 0 0
S: 1 1
😧 1 1
ADSL2 framing
MSGc: 59 12
B: 133 34
M: 1 1
T: 1 4
R: 0 0
S: 0.9935 0.9824
L: 1079 285
😧 1 1
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
Re: Have I been put onto the wrong product?
22-03-2009 1:00 AM
You are on ADSL2 if you use about 1MHz bandwidth - the same as ADSL MAX
ADSL2+ if you have the capability to access 2MHz (approximately)
The majority of your signal will be in the bottom 1MHz anyway - but you are not going to get much speed improvement.
But you are still in training phase...
22-03-2009 1:10 AM
Have now been looking things up via google and wonder if I should have a new filter that's ADSL2+ compatible. I've not seen it mentioned anywhere here that I should get a new filter but it looks as though that might let the full speed come up.
22-03-2009 2:01 AM
ADSL2 uses a signal that occupies roughly 1MHz of bandwidth - which is the same as ordinary ADSL.
ADSL2+ uses twice as much bandwidth.
22-03-2009 7:57 AM
I assume then that it's the name/description of the microfilters that's been changed rather than a new improved product.
As to download speed, is the difference between the signal range used by ADSL2 and ADSL2+ caused by settings at the exchange, the quality of the line itself or something else I haven't thought of?
22-03-2009 12:22 PM
can you log into your router and look for a setting that lets you pick which adsl mode to use and force it to sync with adsl2+.
my netgear dg834g has 4 options. auto,adsl.adsl2 and adsl2+
22-03-2009 1:20 PM
It automatically senses the type of connection and if I set it using the wizard or not I still get the same speeds. There doesn't seem to be a way to choose which sort of ADSL you want as there is on yours.
22-03-2009 2:32 PM
i asked axis-bbyw what happended in his case and seems a game of ticket tennis is in order as axis informs me that his line being stuck on adsl2 is down to BTw and the information given to him by BTw is some backend work needs doing.
snip from a ticket axis got.
hope you dont mind me using that snip from your ticket axis
Quote I have only today
received feedback on this issue from our account manager within BT Wholesale and
they have advised they have done some backend work to try and correct the issues you
are experiencing with your service.
22-03-2009 2:38 PM
And it's just reared it's ugly head again, so it's a current ticket issue as well.
22-03-2009 3:15 PM
I added something about the low speed and it looking like ADSL2 instead of ADSL2+ to my ticket for going over to the 21CN trial. They were supposed to be replying next to the ticket last Friday but I put my first speed query in before that so maybe someone is looking into it already ........ or maybe not .........
24-03-2009 10:06 AM
It might be better named "Why have I been put on ADSL2 instead of ADSL2+?
I'm aware of several people with his problem, but unless you are
(a) Realise the difference between the two products
and
(b) Know how to use your router stats to diagnose this
and
(c) Be ver persistent
You won't get anywhere.
PN's fault checking for 21CN is identical for ADSL MAX(ADSL1)
Since ADSL1 and ADSL2 use the same bandwidth, no errors specific to ADSL2 or ADSL2+ are ever going to be found.
It is necessary to spend about a week bouncing stuff backwards and forwards until you get the threat about sending the boys round:-
Quote I have further tested your line, but the BT testing service has still not shown any issues with the service.
Now this does not mean there is not a fault, but the only step we have left is to escalate this issue with BT.
I must make you aware before we do this, that if BT further investigate and confirm that there is no fault, or that the issue is being caused by anything at your side, then they charge a failed fault check fee to you, which starts at £144.00 +VAT.
Please let us know if you would like this escalating further.
Since this was a re-occurence of the same fault, I was able to write:-
Quote Can I refer you to your answer of 12/3/09 @ 14.24:-
We are pleased to be able to inform you that a member of our Customer Support
Centre has now escalated your Question [number 27112413 ]
for further investigation.
The following comment was added to the Question
Jeremy,
Many apologies for the delay in getting an update on this issue. I have only today
are experiencing with your service. If you could let me know if you are still having
issues with the service so that we can get this further investigated for you.
I have also raised this issue with my line manager as the initial complaint i raised
for you with our account manager with BT has still not be answered.
Previously (apart from a few queries about progress reports), this was the latest stage before achieving ADSL2.
24-03-2009 10:26 AM
so i would like to thank axis-bbyw and the others right now for being the guinea pig's that will improve the fault finding process on adsl2+ for all us poor soul's on currently on non WBC enabled exchanges.
@axis. have you seein an increase in your downstream atten on adsl2 compared to adsl?
i ask as there is another customer on the trial that says they where getting 6mb on adsl but from info on pn test on his line now the atten/loop loss on his adsl2/adsl2+ line is 49db and syncin at 3000ish kbps which i would of thought if they had 6mb on adsl there atten would of bein lower when they where on adsl
his upstream seems capped so i adviced him to pm jameseh and wait for that to be uncapped before going deeper into solving his problem as you never no the reorder jameseh puts in might just sort the downstream out to. anything's possable it seems with adsl2+
24-03-2009 10:43 AM
This is spread over 3 routers and several months, but matches PN's "loop loss" tests.
Noise margin has been all over the place - but DMT allows me to run a stable ADSL2 connection at 3-4dB Noise Margin.
Because there is a fault, I'm not using DMT and BT are pleased to give me a 8-9dB target noise margin
I expect things to go wrong on a trial - but I would also expect PN to fast track ADSL2 / ADSL2+ problems.
They don't appear to have any special diagnostics in place, other than "refer to BT Wholesale" if you push hard enough.
24-03-2009 10:51 AM
cheer up axis could be worse the guy in this thread has what seems to be a 15 or 18db target snr looking at his PN test's
Quote 8-9dB target noise margin
http://community.plus.net/forum/index.php/topic,75166.0.html
asbo breaks into song. all ways look on the bright side of life
24-03-2009 10:57 AM
PN said there was no such noise margin
