Have I been banded?
- Have I been banded?
Have I been banded?
04-05-2012 2:23 PM
I wonder if anyone can help before I involve PlusNet directly again? I suspect that many settings were changed at the PlusNet end to try to fix, which has put things out of balance.
I include the following data. I know the line is capable of 8mb as we've had around that for the last month. I'm doing my best not to leave PlusNet, but currently the speed is not good.
TX Cells RX Cells TX CRC errs RX CRC errs
23889 69119 0 0
Mode State Up Speed Down Speed SNR Margin Loop Att.
ADSL2+(G.992.5) SHOWTIME 444937 4544000 8 35
PlusNet Profile reports the speed as 7.1mb !
BT Speed checker
Download speedachieved during the test was - 0.02 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 4.01 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Re: Have I been banded?
04-05-2012 2:30 PM
I know Matt did an SNR reset which seemed to fix things at the time, but it looks as though you've been banded again and will need someone from Plusnet to look at it.
04-05-2012 2:44 PM
I haven't tried another router as I am convinced that this one is fine. It all started with someone knocking the socket here, before that we were happy. The temporary issue, then triggered a low IP Profile, meanwhile the PlusNet staff were changing settings even though I told them straight away it was a local fault which was now fixed, and they couldn't for some reason see it was a BT profile issue.
Before that, the connection was fine @ 7-8mb continually.
04-05-2012 4:45 PM
05-05-2012 11:06 AM
The connection was reset (remotely I presume) some 40 minutes ago and we have some improvement. Lets hope it holds and improves further!:
Uptime: 0:42:11 (remotely reset I think, up a day or so before that)
29838 384568 0 2
ADSL2+(G.992.5) SHOWTIME 444937 6325838 11 35
Download speedachieved during the test was - 5 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.58 Mbps
Upload speed achieved during the test was - 0.38Mbps
09-05-2012 9:11 AM
I'm afraid things have gone bad again - only this time its because BT had an issue at the exchange with the phone lines and we were disconnected several times before our phone line came back to life!
PlusNet's profile seems to be at 4mb (usually its 7.1mb). We normally get 7-8mbs download. Details below:
32675 216838 0 12
ADSL2+(G.992.5) SHOWTIME 443928 6040000 10 35
Download speedachieved during the test was - 0.32 Mbps
IP Profile for your line is - 5.19 Mbps
Upload speed achieved during the test was - 0.36Mbps
PusNet:
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
4 Mb
09-05-2012 12:26 PM
Download speedachieved during the test was - 3.37 Mbps
IP Profile for your line is - 5.41 Mbps
377359 5046410 0 119
ADSL2+(G.992.5) SHOWTIME 443928 6135958 9 35
Uptime: 3:02:07
09-05-2012 3:21 PM
I've raised your profile to 5900 to allow for your new BT IP profile. It seems that when you were having problems our profile was reduced to 4000, but now it's back up that adjustment I made should improve your speed. The good news is that the banding didn't get re-applied so there's no restrictions in that sense. The target SNR is 9dB and it's currently 10dB. As I lifted the banding on the 4th I can't alter the SNR until the 14th. Give us a shout then if it hasn't reduced by itself.
Jojo
09-05-2012 3:48 PM
SNR is currently 9.
I do think the line supports 7-8 Mbs though as it always has done - will this self adjust in time?
Thank you.
09-05-2012 9:35 PM
There's a chance we could squeeze close to 7Mbps if we get the SNR to 6dB. It can sometimes take a while for the target to drop down by itself, so if it's not changed by Monday and the line has been stable I'll try setting it for you. I'm not sure whether you're currently using the test socket but if you can I would recommend it for the best performance. Give us a nudge on Monday if you don't need us beforehand.
Jojo
