Has this morning's latency fix helped?- 27th January
- Has this morning's latency fix helped?- 27th Janua...
27-01-2010 9:27 AM
See the planned maintenance post here.
We're interested to know whether or not this work has helped to improve/fix the problems mentioned in the current Service Status thread. Hopefully it has.
Can people keep their eye on things over the coming days and report back with their findings?
Re: Has this morning's latency fix helped?- 27th January
27-01-2010 10:24 AM
Plusnet Technology
27-01-2010 12:42 PM
B.
27-01-2010 5:45 PM
Things have definitely improved!
I replied in more detail earlier here: http://community.plus.net/forum/index.php/topic,82105.msg683157.html#msg683157
Thanks again
27-01-2010 8:00 PM
This hasn't worked for me, I live in Manchester and have a constant ping rate of 130+ms
Though at 12 midnight to 8am i get 70ms.
This is unacceptable, have you tried playing Modern Warfare 2 or any other computer game when you 1/2 second behind everyone else 😕
27-01-2010 8:02 PM
C:\Users\Barry>tracert www.plus.net
Tracing route to portal.plus.net [212.159.9.2]
over a maximum of 30 hops:
1 5 ms 1 ms 1 ms www.routerlogin.com [192.168.0.1]
2 * * * Request timed out.
3 64 ms 63 ms 81 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 67 ms 66 ms 65 ms te2-1.pcl-gw01.plus.net [212.159.1.113]
5 85 ms 64 ms 136 ms gi5-8.ptp-cr01.plus.net [84.93.224.48]
6 285 ms 54 ms 248 ms vlan2657.ptp-elb01.plus.net [84.93.224.36]
7 367 ms 91 ms 68 ms portal.plus.net [212.159.9.2]
Trace complete.
C:\Users\Barry>
Spotty results, although It may be because of me being on the DLM trial (although it was fine two nights ago at the same sync speed).
I also note the lack of ping response from the gateway - is this intentional, or is it just 'busy' ?
I'll gateway hop a few times and see what I come up with.
B.
27-01-2010 8:07 PM
Tracing route to portal.plus.net [212.159.8.2]
1 * 1 ms 1 ms www.routerlogin.com [192.168.0.1]
2 119 ms 113 ms 175 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 188 ms 166 ms 104 ms vl604.thn-gw1.plus.net [84.92.4.169]
4 304 ms 116 ms 111 ms te3-2.ptn-gw01.plus.net [212.159.1.53]
5 193 ms 122 ms 165 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
6 152 ms 198 ms 306 ms vlan7.pih-gw3.plus.net [212.159.0.26]
7 123 ms 119 ms 144 ms if25.pih-lb04.plus.net [212.159.0.18]
8 141 ms 199 ms 221 ms portal.plus.net [212.159.8.2]
Trace complete.
C:\Users\Barry>
So, it's not looking grerat atm.
B.
27-01-2010 9:16 PM
I would say the the change has improved things but not completely fixed them. I regularly play Second life and since being moved to the 21CN network found it largely unusable from about 7 pm to 9pm. whereas outside of those hours it was fine. Since the change it is now possible to play it during those hours albeit with some difficulties - usually timing out when moving from one region to another. Before the move this was not a problem.
BTW my ping time to www.plus.net is 73ms
27-01-2010 9:22 PM
I too am in the Manchester area.
this is unacceptable as it is now the 2nd or 3rd week this has gone on for with absolutely no sign of the problem being solved.
guess you are still going to take my monthly payment in full though!
27-01-2010 9:25 PM
Has anybody with access to both a 20CN and 21CN line on the same exchange compared the ping times?
27-01-2010 10:27 PM
28-01-2010 12:54 AM
i have had poor performance all day every day since this started on both of my accounts (home and work - 2 different locations)
is there any light at the end of this tunnel or we just going to be told "thank you for your patience" for the next god-knows how long?
I am not a techie by any stretch of the imagination but in any business if you don't provide the service you advertise you don't charge the people for it. you might want to think about that the next time you draw our monthly charges ..... and perhaps don't. Could even refund for the last month's awful service you have provided.
28-01-2010 2:18 AM
A tracert highlights a lag spike/bad connection mainly to [ lo0-plusnet.pcl-ag04.plus.net ], wherever that is. And thats only to [ ntp.plus.net ].
Note great, considering of course that my router checks periodically for ping to gateway, and if it fails too many times it logs a dropped sync, and then reconnects, or the connection is simply crap.
Spent 4 weeks so far on this High Speed connection, and it's been pretty dire.
28-01-2010 7:32 AM
28-01-2010 8:54 AM
I'm working from home today so if you need me to do any tests/checks at certain intervals I'll be glad to help.
