Has something happened in London today? 11th march
- Has something happened in London today? 11th marc...
11-03-2015 4:26 PM
Routing to US is all over the place, taking on average 7 hops just to pass through London alone and being routed to London then via NL to US
FTTP 500 regrade from Tues 28th November
Message 1 of 9
(1,486 Views)
8 REPLIES 8
Re: Has something happened in London today? 11th march
11-03-2015 7:32 PM
So is it squeaky wheel time? Has something happened to routing to US via London or not? Or did you finally change from level3, but to a worse provider for traffic to US?
Message 2 of 9
(810 Views)
12-03-2015 10:15 AM
Hi Gus,
Do you know what kind of ping times you were seeing prior to this to the same site/server?
Message 3 of 9
(810 Views)
12-03-2015 10:34 AM
Historically with level3 they used to be around 130ms until mid winter then it increased too the 170-180. Its been that way since the big winter storm hit the US.
But this new routing is worse, regularly seeing lost syncs with the games embedded irc chat. level3 were bad but ntt.net are worse from my point of view.
edit: added a 5min trace, note this if off peek, yet I get 200ms its worse at peek times
Message 4 of 9
(810 Views)
12-03-2015 11:46 AM
From here, 5 minutes ago if it's any help.
ping 192.184.14.42
Pinging 192.184.14.42 with 32 bytes of data:
Reply from 192.184.14.42: bytes=32 time=179ms TTL=51
Reply from 192.184.14.42: bytes=32 time=178ms TTL=51
Ping statistics for 192.184.14.42:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 178ms, Maximum = 179ms, Average = 178ms
tracert 192.168.14.42
Tracing route to 192.168.14.42 over a maximum of 30 hops
1 1 ms <1 ms <1 ms 192.168.1.254
2 34 ms 32 ms 33 ms lo0-central10.ptn-ag04.plus.net [195.166.128.193]
3 33 ms 32 ms 33 ms link-a-central10.ptn-gw01.plus.net [212.159.2.140]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
Think you can probably guess the next 20!
ping 192.184.14.42
Message 5 of 9
(810 Views)
12-03-2015 8:09 PM
Another trace at start of peek gaming time
Message 6 of 9
(810 Views)
12-03-2015 8:12 PM
I think your traceroute is showing both directions of traffic - it looks like the return path is via Amsterdam.
Message 7 of 9
(810 Views)
12-03-2015 8:21 PM
It looks like a standard outbound traceroute, mine is pretty similar:
[tt]traceroute to 192.184.14.42 (192.184.14.42), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 1.289 ms
2 lo0-central10.pcl-ag05.plus.net (195.166.128.186) 42.957 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.178) 39.984 ms
4 xe-1-2-0.pcl-cr02.plus.net (212.159.0.210) 19.962 ms
5 195.99.126.98 (195.99.126.98) 21.272 ms
6 core4-te0-12-0-20.faraday.ukcore.bt.net (109.159.249.153) 21.436 ms
7 peer2-et-10-3-0.faraday.ukcore.bt.net (62.6.201.199) 34.822 ms
8 213.137.183.88 (213.137.183.88) 27.147 ms
9 82.112.115.185 (82.112.115.185) 23.300 ms
10 ae-1.r03.londen05.uk.bb.gin.ntt.net (129.250.6.230) 179.116 ms
11 ae-15.r03.amstnl02.nl.bb.gin.ntt.net (129.250.6.25) 178.398 ms
12 ae-4.r23.amstnl02.nl.bb.gin.ntt.net (129.250.2.146) 33.270 ms
13 ae-6.r23.asbnva02.us.bb.gin.ntt.net (129.250.6.176) 120.973 ms
14 ae-0.r22.asbnva02.us.bb.gin.ntt.net (129.250.3.84) 131.760 ms
15 ae-2.r21.lsanca03.us.bb.gin.ntt.net (129.250.3.55) 188.018 ms
16 ae-2.r04.lsanca03.us.bb.gin.ntt.net (129.250.5.70) 197.230 ms
17 ae-22-100.r04.lsanca03.us.ce.gin.ntt.net (129.250.200.138) 180.011 ms
18 192.184.12.9 (192.184.12.9) 178.963 ms
19 192.184.14.42 (192.184.14.42) 195.643 ms[/tt]
Message 8 of 9
(811 Views)
12-03-2015 8:41 PM
Same here.
--- 192.184.14.42 ping statistics ---
50 packets transmitted, 50 received, 0% packet loss, time 49069ms
rtt min/avg/max/mdev = 167.845/174.111/187.179/4.475 ms
1 192.168.0.254 (192.168.0.254) 0.890 ms 0.879 ms 0.886 ms
2 lo0-central10.pcl-ag01.plus.net (195.166.128.182) 9.913 ms 10.853 ms 10.786 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.160) 9.176 ms 10.116 ms 10.055 ms
4 xe-10-0-0.pcl-cr01.plus.net (212.159.0.192) 10.640 ms 10.562 ms 10.335 ms
5 195.99.126.96 (195.99.126.96) 10.841 ms 10.377 ms 10.348 ms
6 core3-te0-2-0-19.faraday.ukcore.bt.net (109.159.249.5) 10.349 ms
core4-te0-12-0-18.faraday.ukcore.bt.net (109.159.249.17) 11.804 ms
core3-te0-0-0-26.faraday.ukcore.bt.net (109.159.249.49) 10.079 ms
7 peer2-et-8-3-0.faraday.ukcore.bt.net (62.6.201.197) 11.546 ms 10.227 ms 10.134 ms
8 213.137.183.70 (213.137.183.70) 9.698 ms 213.137.183.64 (213.137.183.64) 9.728 ms 213.137.183.66 (213.137.183.66) 9.139 ms
9 82.112.115.185 (82.112.115.185) 10.406 ms 10.326 ms 12.109 ms
10 ae-1.r03.londen05.uk.bb.gin.ntt.net (129.250.6.230) 168.963 ms 171.374 ms 170.429 ms
11 ae-15.r03.amstnl02.nl.bb.gin.ntt.net (129.250.6.25) 183.304 ms 186.740 ms 185.924 ms
12 ae-4.r23.amstnl02.nl.bb.gin.ntt.net (129.250.2.146) 17.677 ms 18.340 ms 26.053 ms
13 ae-6.r23.asbnva02.us.bb.gin.ntt.net (129.250.6.176) 108.078 ms 99.847 ms 102.809 ms
14 ae-0.r22.asbnva02.us.bb.gin.ntt.net (129.250.3.84) 102.866 ms 102.624 ms 97.915 ms
15 ae-2.r21.lsanca03.us.bb.gin.ntt.net (129.250.3.55) 164.899 ms 167.384 ms 201.088 ms
16 ae-2.r04.lsanca03.us.bb.gin.ntt.net (129.250.5.70) 166.620 ms 178.782 ms 163.310 ms
17 ae-23-100.r04.lsanca03.us.ce.gin.ntt.net (129.250.200.122) 170.287 ms 176.589 ms 164.853 ms
18 192.184.12.81 (192.184.12.81) 161.331 ms 166.177 ms 192.184.12.9 (192.184.12.9) 173.093 ms
19 192.184.14.42 (192.184.14.42) 156.795 ms 166.335 ms 180.038 ms[/tt]
Message 9 of 9
(811 Views)
