Hardly any speed on broadband connection.
- Hardly any speed on broadband connection.
20-03-2015 1:59 PM
I've been told to reset the thomson router by putting a pin in the reset button which I did but its made no difference. Can anyone help with this please.
Re: Hardly any speed on broadband connection.
20-03-2015 2:28 PM
20-03-2015 2:32 PM
20-03-2015 2:37 PM
It gives details for logging into your router to log of and back on
To be is to do - Kant
do be do be do - Sinatra
20-03-2015 2:50 PM
I was on to the technical people earlier and after 45 minutes of trying to fix it for me he said it couldn't be done and he raised a ticket for it. So you are a star in my books as I was getting so stressed with it all. So thank you again.
20-03-2015 2:54 PM
20-03-2015 2:56 PM
20-03-2015 2:57 PM
Customer and Forum Moderator.
20-03-2015 2:58 PM
Mary
Quote from: maryf I've been told to reset the thomson router by putting a pin in the reset button which I did but its made no difference. Can anyone help with this please.
Who told you to do that
20-03-2015 3:03 PM
20-03-2015 3:06 PM
20-03-2015 3:11 PM
20-03-2015 3:24 PM
21-03-2015 7:26 AM
Good to hear that you are now sorted.
@Mods,
For tidiness merge this thread with Mary's other thread on phone line problem? If the support agent had taken a joined up view, he'd have realised that this was a post phone line fault issue.
Kevin
21-03-2015 9:51 AM
