Half sync speed
gizmoguy
Half sync speed
Hi all,
I am currently experiencing max download speed of ~6Mbps and a sync speed of ~6.6Mpbs, where I normally get 11-12Mpbs sync. I think my upload speed is also quite low. Please find my line stats below. If someone could look at the line history I would be grateful. Thanks.
Exchange is Leyland LCLEY.
ADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
   ADSL2+(G.992.5) SHOWTIME 490000 6616000 25
14
B
Fixes: 22
Re: Half sync speed
That SNRM figure is grim and might suggest a line fault. Follow the instructions in the speed issues topic - see the link below.
Fixes: 152
Re: Half sync speed
Sorry to hear you're having speed issues.
Our tests aren't showing any obvious cause so I'd recommend going through the links Townman has provided.
 Matthew Wheeler
