Had unlimited Fibre installed today - Speeds less than previous ADSL
- Had unlimited Fibre installed today - Speeds less ...
27-05-2014 5:57 PM
Engineer said the modem was getting the full speed?
Current High-speed Broadband profile from plusnet
Telephone number:
Phone exchange:
ERDINGTON
Estimated line speed:
14Mb (This may vary between 8Mb and 18.5Mb) - Checked on 2014-05-08 13:01:01
Current line speed:
11.2 Mb
BT Speedtest
Download speedachieved during the test was - 9.72 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 0.76Mbps
Anyone got a clue?
My router is a Belkin N750 F9K1103 v1 (01C)
Telephone number:
Phone exchange:
ERDINGTON
Current line speed:
11.2 Mb
BT Speedtest
Anyone got a clue?
Message 1 of 4
(700 Views)
3 REPLIES 3
Re: Had unlimited Fibre installed today - Speeds less than previous ADSL
27-05-2014 6:05 PM
Your IP profile is set correctly but your plusnet one isn't looks like it hasn't been updated from ADSL someone from the DCT should be able to change it or you could if your willing to be on hold for a while call customer support and get them to change it.
Message 2 of 4
(414 Views)
27-05-2014 6:09 PM
Thank you I will try and get it changed then.
Rang PN support and you were bang on. They say it will be done in a couple of hours.
Message 3 of 4
(414 Views)
27-05-2014 6:37 PM
glad it's being sorted for you
Message 4 of 4
(414 Views)
