HUAWEI HG 612 Modem.How to use Lan2 to feed local PC
- HUAWEI HG 612 Modem.How to use Lan2 to feed local...
11-03-2013 9:53 AM
I wish to move my useless HG 582 wireless router nearer to the centre of my house to try and get a working wireless network without having to run more than ONE ethernet cable. My Modem is adjacent to the PC it makes sense to utilise the "Spare" ethernet port of the HG612 otherwise whats it there fore?
Re: HUAWEI HG 612 Modem.How to use Lan2 to feed local PC
11-03-2013 12:26 PM
Quote from: brianwright22
You need to take the hg612 out of bridge mode and put it in routing mode.
This shows the settings I used.
http://npr.me.uk/hg612/
You also need to disable DHCP in the TG582n.
11-03-2013 1:57 PM
I hope this makes sense
11-03-2013 2:11 PM
Instructions here -- click on link on right of page:
http://huaweihg612hacking.wordpress.com/about/
Are you sure you've got a Huawei modem.
If it's a ECI modem then that's more difficult.
11-03-2013 3:10 PM
jim:quote
11-03-2013 3:23 PM
Quote from: npr I thought you had already unlocked it.
Many thanks for your help so far. But there is a problem unlocking my Modem
Interesting this is the site I used to try and unlock the HG612. It states configure the ethernet to 192.168.1.100 well on the PC setup it won't except the last two 00.I don't think thats an issue.
What is more important is that it says connect the PC/Laptop to Lan2 well this is the one that has limited or not function. Carrying out the instructions is very straight forward but my Modem does not boot the DSL after releasing the reset with the 5sec action.Therefore there is no broadband connection when selecting 192.168.1.1. My version is the HG612 3B would this make any difference?
jim:green quote fixed [/color]
11-03-2013 3:56 PM
I used those instructions and they do work
11-03-2013 4:24 PM
Quote from: brianwright22 It states configure the ethernet to 192.168.1.100 well on the PC setup it won't except the last two 00.
It's a valid IP, it will accept that address you're doing something wrong.
Never mind you can use any address in the subnet, try 192.168.1.11
Have you downloaded the unlock firmware, you'll need that before you can go much further.
The instructions do work, read them again and start afresh.
11-03-2013 8:13 PM
I'm sure Il'l get there eventually I'm only interested in getting the Lan2 port operational
jim:quote
11-03-2013 10:07 PM
11-03-2013 10:30 PM
Quote from: apjashley1 Don't you need to be on the non-BT firmware for this to work?
I have since heard that even if the unlocking worked on my version 3B modem it will not be possible to operate Lan1 & Lan 2 independently. This is because it is not configured as a dual hub.
I have checked the unlocking method again and my modem will not boot up when powered and configured holding down the reset button.It refuses to boot and I have tested the reset button iternally for continuity .
I think I will have to accept that my modem stays as it is.
11-03-2013 10:44 PM
That's not true, I have one doing exactly that.
I've also posted the config details telling you how to do this.
11-03-2013 11:20 PM
Quote from: brianwright22 I have checked the unlocking method again and my modem will not boot up when powered and configured holding down the reset button.It refuses to boot and I have tested the reset button iternally for continuity .
Unplug everything from the HG612 modem including the power cable, the ethernet cable from lan1 and the rj11 cable from the BT Socket ( the modem should have no cables plugged in at all ). Now connect an ethernet cable directly from your pc to the modem's lan 2 port, and configure your pc's ethernet as described in the guide. Now hold in the reset button, plug in the power cord, and wait 10 seconds ( to be sure ). Release the reset button.
Now follow the rest of the instructions in the guide
If you still can't configure your ethernet as you suggested earlier, use another pc.
Good luck
12-03-2013 5:53 PM
Rather strange perhaps I have a duff lan2 port Modem.
Interestly my Vista Laptop says there is a problem connecting to the ethernet device and tries to repair but will not connect
dick:quote
12-03-2013 7:32 PM
That suggests you haven't put the laptop's ethernet port on a static IP in the range 192.168.1.[2-252]
