HTTPI, Protocol or small webserver?
Fixes: 4
What is this line in the router used for,
9 HTTPI            tcp                      8080                      enabled
Is it for external web access to the router, ie a small web server,  or is it allowing the HTTPI Protocol to work returning on port 8080.
Or neither ?
Regards
Gary
Fixes: 6
Re: HTTPI, Protocol or small webserver?
I believe it's something to do with "web Browsing Interception".
If you disable the above in the GUI then the HTTPI service becomes disabled.
Fixes: 4
Strange, i have web Browsing Interception disabled, i just checked to make sure.
Very odd.
Fixes: 6
Using firmware version 8.C.M.0
With web Browsing Interception disabled.
service system list name=HTTPI expand=enabled
Idx Name            Protocol        SrcPort  DstPort  Group
  1 HTTPI            tcp                      8080
        Description................ HTTP intercept proxy
        Properties................. proxy
        Attributes................. state port srcip aclip aclif aclifgroup map log forward qoslabel routelabel natpmweight
        User Managed Attributes.... map log natpmweight
        Attribute Values :
        State...................... (administratively) disabled
        Port....................... 8080
        Source Ip Selection........ auto
        QOS Label.................. None
        Route Label................ None
        NAT Portmap Weight ........ 30
        Ip Access List............. any
        Interface Access List...... any
        Interface Group Access List any
        Map List................... 80:LocalNetwork 1080:LocalNetwork 8080:LocalNetwork
        Logging.................... disabled
        Forwarding................. enabled
Fixes: 4
What the hell is goin' on... Sad
Fixes: 4
Ok so i've restarted my Router earlier today and i do recall turning off that web interception, but it's been up for 44 days and this would be the first time i've restarted it.
I just tried to enable the service from the cli and it appears still disabled after saving etc, so i guess it makes sense that the Router will only make changes after a warm reset etc.
So back to the point in hand, HTTPI=Web Browsing Interception.
cheers npr
