HG612 Stats
samb
HG612 Stats
Hello,
So got my HG612 today and recorded some stats, those in the know (will sit down to learn this stuff at some point!) can you take a looksie see if the stats look okay for 80/20.
DSLAM/MSAN type:        BDCM:0xa415 / v0xa415
Modem/router firmware:  AnnexA version - A2pv6C030b.d22g
DSL mode:              VDSL2
Status:                Showtime
Uptime:                40 min 45 sec
Resyncs:                0 (since 09 May 2014 13:56:12)
Downstream Upstream
Attenuation (dB):
Connection speed (kbps): 79999 19999
SNR margin (dB):        14.6 23.2
Power (dBm):            12.4 0.7
Interleave depth:      1 1
INP:                    0 0
RSCorr/RS (%):          N/A 0.0000
RSUnCorr/RS (%):        N/A 0.0000
ES/hour:                13.9 0
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 40311 Kbps, Downstream rate = 111180 Kbps
Path: 0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 14.6 23.2
Attn(dB): 0.0 0.0
Pwr(dBm): 12.4 0.7
VDSL2 framing
Path 0
B: 239 237
M: 1 1
T: 23 42
R: 0 16
S: 0.0955 0.3781
L: 20107 5374
D: 1 1
I: 240 127
N: 240 254
Counters
Path 0
OHF: 1478572 616165
OHFErr: 6 0
RS: 0 97690
RSCorr: 0 0
RSUnCorr: 0 0
Path 0
HEC: 2 0
OCD: 0 0
LCD: 0 0
Total Cells: 375979311 0
Data Cells: 4909279 0
Drop Cells: 0
Bit Errors: 0 0
ES: 5 0
SES: 0 0
UAS: 21 21
AS: 2447
Path 0
INP: 0.00 0.00
PER: 1.64 3.97
delay: 0.00 0.00
OR: 116.56 64.47
Bitswap: 0 0
Total time = 41 min 9 sec
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 21 21
LOS: 0 0
LOF: 0 0
Latest 15 minutes time = 11 min 9 sec
FEC: 0 0
CRC: 4 0
ES: 3 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 41 min 9 sec
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 21 21
LOS: 0 0
LOF: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Since Link time = 40 min 45 sec
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Thanks Much
Sam
1 REPLY
Fixes: 48
Re: HG612 Stats
Everything looks fine to me samb, the connection looks stable from our point of view too.
Adam
 Adam Walker
